airmatic pump mount
2003 E55 AMG
airmatic pump mount
I think I may have tweaked my pump mount a little to much on the bolt that tightens the springs. What is the correct setting on the "spring" bolts to not make allow it to vibrate without feeling it throughout the whole car. I realize the pump may be on its way out but I would like to check it first before jsut replacing it. Thanks!!
Received 4,435 Likes
'71 Pinto
Replace stop buffer and attachment parts part # 2203270376 washer, 2113270330 bumper, 2113270530 bumper, 2209930301 spring, and 2203270253 spacer tube – quantity 3 approximately $30 total. If you are also experiencing sporadic knocking/rumbling noise when driving over rough roads you may want to consider installing modified bracket part # 2113201743 (for comparison shopping, http://www.parts.com/oemCatalog/inde...D=2&makeid1=67
$111.55), mounting hardware 2113270050 (7.48).
2003 E55 AMG
Rear suspension - Ride control components - Compressor assy - Front bracket W/e63 - W/airmatic suspension 2007 - 2009
Will this fit my 03 E55? What is the difference? I do get the knocking on bumps and can't wait to get it fixed....it drives me nuts!
The other question I have is "quantity 3" Does that mean I need 3 of each item or 3 spacer tubes?
Thanks for the response!!!
josh
josh
