Urgent notice. 03-06 E55's that were involved in the fuel sender recall are bombs.
I've been pretty bummed and its been too hot to get out and work with it, so the car's been sitting out in the garage idle, and dumped so low I can't move it.
So, today I got out in the garage, pulled the seat out, and checked in the fuel bucket. I've been getting a leak on the passenger side. It looks like there's a little fuel pooled around the cap portion, but I couldn't see a leak in the seal. I attempted to prime the pump and checked the Schrader valve on the rail under the hood. No fuel. I closed it and checked for spark using a spark tester. The car is getting spark properly. Upon pulling off the cap of the fuel bucket and struggling to get the clip off the outside, I noticed the plastic around the harness plugs is burned and it looks like it's melted around where they plug in above the fuel pumps/bucket.
I've read a few things about burned harnesses, but haven't seen an exact fix. I'm not sure if I should order an entirely new fuel bucket with pumps, a new harness, or what. I'm guessing I'll start with a harness. Does anyone know the typical reason for the short in the harness? Is it related to the fuel leak?
Oh, and I'll file a new complaint on the NHTSA sight tonight. I'm sick of this crap.
(pics to come of the sending unit and burns)
In the meantime, I finaly used an exacto knife to trim back some of the melted plugs and ended up pulling them out. It ended up snapping some off because it was fused together so badly. Here's the pic of the fuel bucket cap. I'm going to have to replace the whole unit regardless to fix the leak, so I'm debating now whether I should get the OEM MB part, or go with the Airtex aftermart one. I'd probably rahter have the OEM pumps/bucket just in case MB ever is forced to take action on this issue.
From the top:
From the bottom. Notice you can see right through it:
- Two fuel pump relays
- New fuse (already installed)
- Fuel pumps and bucket assembly (passenger side)
- Fuel pump harness
- Fuel filter
Anything else I should consider changing? The sender unit on the driver's side looks fine and I don't see any apparent signs of leakage.
Please send those pics of the burn to NHTSA. They would probably want the part as well so don't throw it away.
I didn't think there was a leak in the two seal rings when I expected them (the black rings that screw on over the senders to seal them in?). I'm guessing you think I should replace them while I'm in there even if I don't see a leak?
It seemed to me that the leak was coming through the melted hole in the sender, but I could be wrong.
Edit I found both seals and rings.
Have you read the NHSTA stuff? Mercedes basically says this is unrelated to the recall, so shove it.
My service adviser was a hoot. Very supportive but little he could do. He calls and explains the problem and says it will take a few days to get the parts. I know this is really common, so I ask him to check if he has them.
Surprise, surprise, all the parts are kept in stock.
Oh no, it isn't a common problem at all.......
is it more than likely the dreaded tank leak? car has 3/4 tank of fuel but no GAS smell.
http://www.news-journalonline.com/ar...Seminole-crash
You can see the burns on the connectors in the harness plug:
The worst part of the burn. You can see it melted through the plastic all the way on the back side of the port:
These plugs are basically fused into the plastic here. Can't pull them yet.
I just recently had to change my fuel sending unit on the driver side as well. Didn't think the gas smell was so bad until I saw fuel spilling out of the bottom of my car
Question. On the passenger side is it normal to see gas like in your pic? Is it because thats where the gas tank is?
