Urgent notice. 03-06 E55's that were involved in the fuel sender recall are bombs.
Old May 16, 2014 | 06:48 PM
  #701
FlyByNight's Avatar
05 E55
call local MB and they gave me the following for my 06 now:
211-470-45-94 passenger
211-470-49-94 drivers
211-471-05-79 seal rings
go figure. Don't think it could be more confusing with all these part numbers.
Old May 16, 2014 | 07:13 PM
  #702
FlyByNight's Avatar
05 E55
So, looking at site after site to get parts for my 06 E55 in another country... Of all of them... including MB fort Lauderdale, autohausaz, partsgeek... I got the best price so far from:
https://mercedespartscenter.com/index.cfm
This is my shopping cart for the following part numbers, total is $828.16 for both drivers and passenger's sending units and O rings. Think anyone know of a place which can do better? Thanks.
Description MSRP Price Your Price Core Price Qty Total Cost
OEM Catalog
SENDER UNIT $505.00 $377.76 $0.00 $377.76
OEM Catalog
SENDER UNIT $550.00 $411.64 $0.00 $411.64
OEM Catalog
SEAL RING $26.00 $19.38 $0.00 $38.76
Loren
Old May 16, 2014 | 07:43 PM
  #703
novae500's Avatar
W211
Hopefully the parts u ordered are the latest and greatest design for the fuel units.
Old May 22, 2014 | 02:28 PM
  #704
copterguy's Avatar
2012 CLS63 AMG
Hello, revisiting this thread after a long wait, not browsed the whole of it yet, but trying to find a few simple answers if someone can past the posts or lead me in the right direction. My 06 CLS is having the leaky sender problem, has for a while. I tried what someone else did and used a sealant around the top of the sender to see if it would stop the leak, but no, it didn't. Now it's leading to my check engine light illumination, as slight emissions leak, I'm quit sure it's the leaking sender. Anyway, only the drivers side is leaking (didn't know there was another, is there?) My question is, is replacing the sender easy? like unscrewing it from top or do I have to lower the gas tank and get at something else? I see the parts list someone posted, so, I know where to get the parts, just want to make sure about the replacement procedure. A good DITY would be nice. =0) Thanks.
Old May 22, 2014 | 03:28 PM
  #705
novae500's Avatar
W211
there is another post of a DIY for replacing the sender units. If you do attempt, i would make sure that there is less than 1/4 tank of gas. You will need to disconnect the wire connectors that are inside the tank itself the ds from the ps side, and make sure the orientation of the units are the same taken out/put back into place.
Old May 28, 2014 | 09:24 PM
  #706
£ C43 £ AMG £'s Avatar
E55K AMG
and check the relay and loom
Attached Thumbnails Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-dsc_0336.jpg   Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-dsc_0338.jpg   Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-dsc_0332.jpg   Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-dsc_0333.jpg   Urgent notice.  03-06 E55's that were involved in the fuel sender recall are bombs.-dsc_0330.jpg
Old May 30, 2014 | 07:00 PM
  #707
Miniac's Avatar
E55 AMG
Just filed my complaint. DS sender is weeping fuel. parts should be in Monday.
Old May 30, 2014 | 09:48 PM
  #708
copterguy's Avatar
2012 CLS63 AMG
Did you order from Mercedespartscenter.com? Looks like cheapest I've found so far. I've not yet ordered anything, but want to.
Old Jun 2, 2014 | 04:56 PM
  #709
Miniac's Avatar
E55 AMG
No I get a discount at the Stealership. So it came out ot be 440.00. I had to pick up a few other things I had on order so it was easier. Had to order the passenger side as well when is seen the plug was melted on three of the leads.
Old Jun 2, 2014 | 06:44 PM
  #710
Miniac's Avatar
E55 AMG
Copterguy pm'd you one of the diy I'll be using when I change mine out this week. If I can ad any tips I'll pm those to you as well.
Old Jun 2, 2014 | 08:25 PM
  #711
copterguy's Avatar
2012 CLS63 AMG
Many thanks, hope it goes well and is reaaal easy.
Old Jun 11, 2014 | 02:32 PM
  #712
Miniac's Avatar
E55 AMG
Changing out the sending unit's is fairly easy but time consuming. The first tank the fuel gauge was slightly off but after you fill it back up it seems to calibrate it's self and run true.
Old Jun 13, 2014 | 10:16 PM
  #713
BC928's Avatar
2006 E55, Various other German and ‘Murican
Where is that part of the loom located?
Old Aug 21, 2014 | 01:03 PM
  #714
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
My dealer gave me different part numbers, what's the difference?
211-470-51-94
211-470-17-94
Old Aug 31, 2014 | 01:46 AM
  #715
Anyone know the correct time to do only the drivers side fuel sender unit?
Old Aug 31, 2014 | 05:25 AM
  #716
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Mercedes calls for replacement at 60,000 miles.
Old Aug 31, 2014 | 08:17 AM
  #717
Sorry, I meant labor rate from alldata. What should it cost just for one side
Old Aug 31, 2014 | 08:19 AM
  #718
MindBend's Avatar
'05 E55
Part is $505 list. I'd suspect labor to be 1.5-2 hours.
Old Aug 31, 2014 | 08:33 AM
  #719
I figured that, I just wish I had something on alldata to prove it
Old Aug 31, 2014 | 08:54 AM
  #720
MindBend's Avatar
'05 E55
Do it yourself...not a big deal at all.
Old Aug 31, 2014 | 09:47 AM
  #721
It's too late now, I got the dealer price at $430. But they're trying to charge me $400 for labor, what's usually the hourly rate and the correct labor time for this job
Old Sep 15, 2014 | 06:07 PM
  #722
SRTnAMG's Avatar
2003 Tectite Grey E55 AMG, 2003 N-SRT4
how would I know if Im eligible for recall? Im third owner of my 2003 E55
makes me wanna keep a fire extinguisher in the car... even though its always good to have one whether or not your vehicle has a recall .
Old Sep 15, 2014 | 07:52 PM
  #723
ThroughTheEsses's Avatar
2001 M Roadster, 2005 E55 AMG Estate
I don't think there's actually been a recall. If there was, I've got a nice expensive bill to send them.
Old Sep 15, 2014 | 07:55 PM
  #724
SRTnAMG's Avatar
What have you repaired?
Ive only smelled gas outside of the car, its not very strong and I had a full tank after getting home from a long drive in 95 farenheit miami weather
Old Sep 16, 2014 | 07:11 AM
  #725
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
The pulse dampener on the back of the fuel rail has an o-ring that goes bad. Pop the hood and sniff the back of the motor.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
