Q: What is best pump for rear resevior
After seeing my IATs in hot weather, I am going to do rear tank now, and meth when the throttle body goes on since the SC comes off anyway. In the mean time, I have read all there is to read on thesubject. Some are running dual pumps, and some CM 90's. Since there is 40+ feet of 3/4" hose, I want to do one large pump in trunk that can keep flow at 10+ GPM. Any options there? Thanks guys!!!
Opinon:
Meth negates the need for rear tank.
If I had it to do all over again I would have done meth as my first mod. I may have split the I/C cooling circuit, but I probably would not have upgraded the HE and pump (unless the pump stopped working).
CLS55 & CL CK60
PLATINUM SPONSOR
Sorry to bust up the party but one large pump will only net you about 3- 3.5 GPM, with a rear tank set up.. To much back pressure and head pressure.. I have one big pump and one intank bilge pump to feed it and still only see about 4.5 GPM real time.. Going to upgrade the intank pump to a 2000 GPH rule and see if that helps but doubt I will see over 5 to 5.5 GPM real time..
I also would like to see 10 GPM but feel that is a pipe dream on our system..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
