Heat Exchanger / IC Circuit seperation
Old Sep 5, 2010 | 12:40 PM
Bramage's Avatar
F-250
For those that have spilt cooling system with a Power Steering Res, do you run full flow through the res, or use as fill point only. I know on the DIY it is fill only, however I have heard that many people keep in directly in the loop. the advantage would be a small increase in capacity, and he ability to verify flow (especially is wired ON with accesory on. I was not able to very my flow when doing dyno which makes me cry
Old Sep 5, 2010 | 09:59 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
i have mine setup as a fill point only. capacity of the reservoir is too small.
