Purge control valve connection to intake
Hello!
I am doing engine swap (blew 1st engine before i bought the car:-( and now when new engine is in place i dont know where should purge control valve pipe connect to?? It is the pipe which is at first (from valve backward to firewall) metal pipe (cca 10 mm diameter), then goes into rubber pipe (cca 15mm diameter) and then again metal pipe (cca 10 mm diameter) (which i dont have?)). Now my question is where exactly does these end of metal pipe connect? I know it connects somewhere to intake (purge valve needs vacuum?), but where EXACTLY on supercharger casing?
Does maybe connects on upper little hole on the throttle body shaft (with black rubber insert in it) , because i know that lower hole is blocked on E55 (and used for master cilinder vacuum on S55)? So where exactly does purge control valve line connects to? Thank you guys very much in advance!!
http://www.kkeshtech.com/sheer/Hadi/TB/8.jpg
