Throttle body help
Are you talking about the part that goes to the air box? If so there is a Tab on the top that snaps on and there is a matching one on the back/under side
Actually I was talking about the rubber cover that sits on the throttle body's left side. I guess it's an insulator to protect the electronic thingys in the throttle body from the engine heat.
I was under the impression that I needed it off to put on the throttle body that I'm installing on the car. Plus, I'm having a hard time getting the wire harness unplugged with that cover on the throttle body. Both sides of the harness has this crud on there that's making it hard to come out.
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
well- you are wrong -- that is not designed to come apart... the wiring harness-- be patient and you will figure it out --- I suggest you have someone who has some mechanical ability help you -- it seems you dont have experience working on cars or anything.
Actually I'll just keep working on it myself. Thanks for the advice though. Now if anyone can provide some good guidance I would surely appreciate it.
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
there is a simplier way, mb sells a throttle body extension cable that will connect your old throttle body cable to the new throttle body.
i dunno - only takes me 15 minutes to take off the TB -- I dont see the difficulty. Just take it out -- its simplier than changing your oil -- only thing easier is changing your belts.
Like someone said earlier, that rubber piece is epoxied in. Use a screw driver and pry it off. It'll come off. And the TPS wire extension is not cheap, it's a hundred dollar and I have to order it.
JorJack, what exactly are you trying to accomplish? Are you replacing the t/b with another 74, 80, or 82? Are you removing it to modify it?
Are you aware that if you follow the t/b cable down there is another connector you can separate to remove the t/b?
good luck trying to get to the other end lol,that sucker is down there tight!!!!.I dont see why you need to take off the rubber enless you want to take the tps sensor off the tb.
4 bolts and a flat head to pry the tb off the snout.ohh and those clips on the tb cable can be tricky,I broke mine and just ripped the thing off on my tb adventures when the stupid 82mm tb decided to eat my tb ring gasket and leave me stranded on the highway.
I'm installing a grinded 74mm tb. I think I'm just gonna order another cable and go that route. Looking at the stock tb that's on my car now I just assumed that the rubber housing needed to go back on to my modified tb.
