Problem with my 2005 e55 help!!!
Old Sep 28, 2010 | 04:24 AM
e551986's Avatar
e55
ok here is my problem , when i drive on freeway 80 miles on hour and when i kick down my pedal i feel car is not taking off the normal way(the car keeps going ,but very slow) , i bring my speed back to 60s or less and it become a normal .This doesn't happen every time .ok i took the car to mercedes dealer , i explain the problem , they told me its Transmission air circle pump ( <-- i am not sure about name) they change it and they ****in told me now everything is fine, couple of days later i have same problem .I took the car to mercedes specialist and they change my supercharger it cost me 5500k from MB dealer( i have warranty lol) ,after 3 months same problem again.I even talk another guys who own e55 ,some of them saying is supercharger clutch ( I change my supercharger ,clutch is seperate part?) the other guy told me i have to change after market pulley and Ecu chip to not have that problem .Please someone give me good advice ,and my car is stack .Thanks and sorry for long essay .
Old Sep 28, 2010 | 04:28 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
charge cooler pump, do a search dude tooo much info on that
Old Sep 28, 2010 | 05:14 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
sounds like it could be the intercooler pump. it's a known problem so if yours hasn't ever been changed, it's a good place to start. have a new one put in under warranty or change out to an aftermarket pump like the johnson cm30 yourself for $150 and report back.
Old Sep 28, 2010 | 07:57 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
Intercooler pump, $150. I have one new in box that I can ship to you for $150 if you like, is a cm30.
Old Sep 28, 2010 | 12:36 PM
e551986's Avatar
e55
thanks guys for info , i will chage that too , one more question ,i am looking to get heat exchanger ,its easy to install?
Old Sep 28, 2010 | 01:22 PM
itsmeek's Avatar
No offense here, but if you have already shelled out $6000+ for something that should have cost you $150 and an hour of your time to install- I'd recommend that you take it to a shop to get it installed. Both IC pump and heat exchanger are simple installs.
