Offset check for 20" wheels -- Help from Wheel Whores, I mean Gurus ?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 1, 2010 | 01:31 PM
threeMBs's Avatar
Only MBs - the best or nothing
Originally Posted by tbone
Vic is correct. Lower offsets = bigger lips = wheel face sits closer to the caliper. For example, take 2 of the same car, but add BBK to one of them. The car without BBK can run a lower offset because it has less caliper to clear, resulting in a wider lip.
Here's a link defining offset -
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Again. I stand by what I stated.
Lower offset does not always = bigger lips hence less clearance. I said "identical wheel" - no lips or even with lips but same size lips regardless of offset.
By going from Et34 to Et25 (by pushing wheels outside by 9mm) you're gaining 9mm clearance on the inside (including caliper clearance) not loosing it:
http://www.1010tires.com/WheelOffsetCalculator.asp
Plug in the numbers in the above link by going from 34 to 25 and you'll see what I mean. If you still have any doubts that lower offset (for identical wheel, that's the key) means more clearance and not less call/email Luke at TireRack. I'm confident he'll confirm what I said.
Look at it this way: stock wheels from W211 fit all W212, but not the other way around. Why? Because stock wheels from W211 have offset in mid to upper 30s say ET35-38, while wheels from W212 have offsets around 50 say ET48-ET54. Higher offset wheels from W212 do not have enough clearance for W211 calipers built for lower offsets. But lower offset wheels have no issues clearing any W212 car because it was built to accept a higher offset.
The lower the offset the more caliper clearance you have (identical wheels including lip size, if with lips) not less.
Old Oct 1, 2010 | 04:19 PM
Bellevue_E55's Avatar
2006 Mercedes E55
thx gents I'm going to order soon. Will update with what I got.
Old Jan 6, 2011 | 01:11 AM
tbal's Avatar
Haters crazy
Will 20x10 ET42 work without hitting calipers in the rear? 285/25 tire
Old Jan 6, 2011 | 02:03 AM
sunny_j's Avatar
09 E320 Bluetec
yes
your monarchs are et42 rear
Old Mar 11, 2011 | 02:17 PM
Yosheego's Avatar
2011 E550
I have a 2011 E550 Sedan.
Wheel spec...
19x8.5 (32mm or 45mm offset) <---My two front options
19x9.5 (35mm or 50mm offset) <---My two rear options
He recommend me to do 32 fronts and 35 rears.
the guy says it will sit flush with my fenders...Correct?
Old Mar 27, 2011 | 11:19 AM
Boywonda's Avatar
2007 E63 AMG
Will 20x10 ET32 work without hitting calipers in the rear? I have an 07 E63
Old Mar 28, 2011 | 11:57 AM
  #32
NL007's Avatar
2017 CLS63-S
sorry, dont want to hijack this thread but i have a non-lowered 07-E63 and looking at a set of 19s with the following specs: 19X8.5" et 30 and 19X9.5" et 35 on 245-35 and 275-30.
Can anyone give me an idea if they will sit right, look right and look wide but appropriate....its so hard to judge when people are running all sorts of combinations...
thanks,
Nick
Old Mar 28, 2011 | 08:03 PM
  #33
AK-AMG's Avatar
E55 AMG
Originally Posted by Vic55
The higher the offset (higher ET number) the more the face of the wheel is pushed toward the lip (street side) of the wheel. So a higher ET will allow for more brake clearance but will push the inside of the wheel towards the inner fender.
Generally on W211's ET 32 front and rear on 20x8.5 and 20x10 wheels is fine but tires also play an important role sizewise. On my W211 E55 I ran HRE's 20x8.5 et 32 and 20x10 et 32 and the fitment while not super super aggressive was great for a lowered car. Tires were 245x35x19 and 275x30x19
I am looking at getting a set of HRE's for the E55. With the sizes you mentioned above, will it be ok to run the fronts with +25 instead of +32 or do i risk rubbing?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
