Photos of heat exchanger install
This is the install of a Eurocharged heat exchanger
I had to drill out and remove the old brackets for the lower cooler and very carefully drill holes in the plate
of the exchanger and install 5/32 rivits in to hold it to the heat exchanger remeber if you hit the first row
of the core it is trash only drill the plate id suggest using a drill bit stop only use aluminum or stainless rivits
otherwise corrosion will start. I was able to reuse all the hoses.
eyepass (12-07-2020)
there are 2 clips that stick out toward the re-enforcment that have to be cut off it does not affect the structure
2004 E55, 1997 E320 "Sold"
The 2 clips that you are talking about do have to be cut off, yet after reinstalling the bumper I do not notice the bumper being and weaker or looser, so it is okay in my opinion.
MB: E55 AMG, CL550, E3004M Cab + other makes :)
looks good, I like how it adds kind of an aggressive look when you see it through the bumper..like "oh, that car may have power" lol
[quote=lowprofile;4295936]
>Did you need to notch the bumper cover?
H/E Looks good
I will be doing this 63 conversion and will need to some how fit the two cores i have currently installed..I see this will be a PITA but gotta make it happen
H/E Looks good
Replaces stock! Just a tad larger, just what you need
unless you have already changed your mind and decided to add a pulley
Like i advised you before, you can do something like that and then call these people http://www.bellintercoolers.com/ if you decide to add another one, but you'll need to know how much space you can play with after the EC unit is installed----modification will be required..
hey i got the 03 e55 amg and the power completely cuts out when i try stepping on the gas hard! (i know the s/c working fine)
evry1 saying its the heat exchanger?(preventing me 2 acc fast so the engine dosent blow)
is the the same thing as an IC pump or innercooler?
is the heat exchange that piece in the last pic with EZIERE written on it in blue?
sorry if these Q are silly but im new to the s/c
thanks
thanks
thanks
thanks
Newb here when it comes to Benz performance stuff...
Would a better/bigger HE on a stock E55 benefit anything? Or is it mainly beneficial to those with pulleys...
