List of engine problems... Need help.
Old Oct 28, 2010 | 12:28 AM
benz_addict's Avatar
V12TT
Exclamation List of engine problems... Need help.
1) Bad idle, car misses and is feeling slow. Misfire on #5 and #1.
- Replaced coils, plugs and O2's. No luck. Replace the injectors?
2) Car starts shuttering and randomly turns off when coming to a stop. Doesn't crank right away, takes about 8 tries.
- Replaced the CPS 2 months ago. No luck. Replace again?
3) Supercharger inactive sometimes, still not active with restart. Extremely rough supercharger engagement.
- Bad S/C clutch?
4) ESP unavailable - no accelerator response.
- Replaced accelerator with sensor. No luck.
Old Oct 28, 2010 | 01:02 AM
AMGPilot's Avatar
2004 E55
- Bad S/C clutch?
Do a leak down test anything more than 5% is a major problem
Old Oct 28, 2010 | 01:36 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
If all of this started at the same time, you know it is something else. Bad wiring, ECU, etc.
Old Oct 28, 2010 | 11:44 AM
lowprofile's Avatar
E55
Was any work performed on your car prior to these issues? I agree with PP, it almost sounds like a harness issue, or possibly ECU.
Any pics of the plugs you removed from 1 & 5?
Old Oct 28, 2010 | 11:54 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I gotta ask, have you had it hooked up to Star yet?
Star is much more in depth than average OBDII code reader.
Lemme know.
Have you had any mods installed/been tinkering around inside the engine before all this started? (when I had stalling issues it was a simple vacuum hose that connected to the TB that LOOKED like it was on fine til you tugged on it)
Really sorry bout all these problems, sounds like you have spent a bunch of cash already on it. Gotta be frustrating. DEFINITELY wanna do that leakdown test ASAP.
She burning any oil?
