SPEEDRIVEN | Block Tuner
![](http://speedriven.com/products_parts-brick.jpg)
BLOCK TUNER
OBD PROGRAMMER AND DATA-LOGGER
The Speedriven Block Tuner communicates directly with your vehicle's ECU, allowing you to switch between Speedriven's high-performance software and the factory file in a matter of minutes. It also works as a data-recorder, giving Speedriven an inside look at your car's behavior - allowing Speedriven to give you local technical support from hundreds or thousands of miles away! Simply connect the Block to your car's OBD-II port (just underneath the steering column) and record the data ... then connect the Block to your PC (via USB cable, included), and email the file to Speedriven.
- SUPERIOR TECHNICAL SUPPORT
- REVERT TO FACTORY SPECIFICATIONS AT ANY TIME
- EASILY SWAP BETWEEN PUMP-GAS AND RACE-GAS TUNE FILES
Available for 55 Kompressor AMG, 600 and 65 AMG Bi-turbo V12, and 63 series AMG cars, as well as 550/350 naturally-aspirated Mercedes-Benz. Priced at 495 USD. Special PKG pricing w/ ECU tune.
Unfortunately, no. The $495 is for the box itself. The tune is extra, and pricing can be found here: http://speedriven.com/products_parts.html
We do offer PKG pricing if a client buys the ECU software and the Block Tuner together, though. Thanks!
What is entailed in switching between stock and Tuned ECU programs? Do I need to hook up PC each time?
Can it send info wirelessly to an iphone?
There's no price listed for the 55K
Keep in mind, the Block will store any 2 files - so you can theoretically run a Speedriven (for example) tune for pump-gas / daily driving duties, and a more aggressive tune for mile runs or race gas. You can even - in some cases - compare tunes from several vendors by saving the files on your PC and swapping them out.
Lots of flexibility built-in, as I understand it, but (sadly) no wireless functionality.
Just thought I'd bump this with a new message: if you have a mid-level to heavily-modded 55K in the Chicago area, we'd like to talk to you. PM me.
Thanks!!
Thanks!!
SL55 AMG
really?this is great news,Im so tired of sending my ecu back and forth this will help me out alot.
Is there a link of the software that I can download to mess with and see what its like?
Just need to see if my tuner feels comfortable giving there bins up to alow us to flash,consider me on the list to buy asap!!!
