Help: batteries?
Old Nov 7, 2010 | 07:03 PM
BRH AMG's Avatar
E55 AMG
Help: batteries?
Went out to start the beast the other morning and nothing, no lights no
start nothing. Proceeded to connect battery charger and after about
30 min. car started. Didnt drive it just left the charger on it for about
another hour. Came back later and put my battery tender on it and left it that way for a couple of days. car sits most of the time, only gets driven
3 or 4 times a month, new main batterry april 06. go out today and turn the key on everything comes on but starter will not even initialize (no click). check main battery 12.7 volts. key will not lock or unlock doors.
keyless go inop as well. Any suggestions would be appreciated
Old Nov 7, 2010 | 08:15 PM
buffyclk500's Avatar
clk500
key batteries
Old Nov 8, 2010 | 05:49 PM
BRH AMG's Avatar
E55 AMG
Latest update: Had all the batteries checked, removed main batt and had it ioad tested
and it is good. checked aux batt and good as well. folowed the advice and replaced key batteries, now everything works, but no start
Old Nov 8, 2010 | 06:45 PM
cahiil55k's Avatar
Are you using keyless-go to start the car or just sticking the key in the ignition? I had one strange occurrence with a brand new key/remote where the Keyless Go would not work until I locked, unlocked, and manually started the car with the new key. The problem never returned.
Old Nov 8, 2010 | 07:08 PM
BRH AMG's Avatar
E55 AMG
Have only been using the key at this point. Locked and unlocked the car
several times with both keys. I'll go out and check keyless though. I can unlock car with key in my pocket. that didn't work . Is there a starter fuse? Everyting works, just no crank.
