Engine surge when hot
its a ver y weird problem and happens only when hot, its like the throttle gets stuck.
could this be throttle body getting stuck?
something to do with the super charger?
its booked into the dealers on the 24th, would be good to get to the botom of it before then!
cheers
When I dropped off the car I left it running so I could show the mechanic how the idle was surging - It was only a little surge and you could hear the idle was off, almost like a miss fire, and all along no codes on the dash.
Intake gasket's are replaced and it's purring like a kitten. I took it for a ride and everything is on the money.
My guess this would have been covered by warrenty but I only spent $240 for parts and labor.
It's good to have a buddy that is a MB tech, and I plan to ALWAYS do all the maintenance on the car.
They where located under the super charger, and as I said it runs great, nice idle no more surging.
part numbers for this gasket would be great. also not the surge tank gaskets, but below the supercharger?
cheers
spray WD40/carb cleaner all around the gaskets areas until you find the revs change and then you found the leak..........what ever it is I am sure it will be an easy fix.
Hey buddy whens the next meet, would be nice to see your mods.
Ace Cafe next month? or do you fancy a RWB at brands hatch or Santa pod to test out ours motors?
btw TRAX for sept, ive started a list on MBClub if your up for it this year?
catch up soon buddy!will try and find some time to do some proper investigating with possible leaks, need to check that hose as well in case its come off!
