My AMG maintenance experience after warranty: You may be surprised!
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 21, 2011 | 04:21 PM
starbrite's Avatar
2004 E320
Ok, OK55, we get it !
Old Aug 22, 2011 | 10:10 PM
DML756's Avatar
S55 AMG 03; '68 280SL, 2018 AMG E63s
ongoing cosrs
Including multiple tire replacements for flats, punctures etc, I seem to have been spending something like $0.30 per mile driven since buying the car second hand at 42,000 (approx) miles. (Current mileage 113,000) I now face ABC work and a huge (12 hr per side) motor mount replacement job.
Has anyone else had such an experience???
Old Aug 22, 2011 | 10:18 PM
rondocap's Avatar
Mercedes S55 AMG
That sounds about right, unfortunately. I replaced 5 tires during the 3-4 month winter in the northeast recently. For some reason they seemed to go, even when new and good tires, pretty fast. Maybe it's the 18 inch rims with the weight of the car, I don't know.
I did motor mounts twice within 50k miles, costing between $1,100 to $1,600 each time. (The more expensive one was at the dealer, the cheaper at an indy..DIY can be cheaper but it's not so easy for most)
Old Aug 23, 2011 | 12:11 AM
AMGPilot's Avatar
2004 E55
Ummm we don't have ABC, we have airmatic and motor mounts are NOT a 12 hour per side job
Old Aug 23, 2011 | 04:23 AM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
AMGPilot, he has a S55 not an E55 I think that's where the confusion is. I believe he's saying the 12 hours per side is for the ABC not the motor mounts.
Old Aug 23, 2011 | 04:25 AM
PACougar's Avatar
I can tell you guys where you all went wrong. You should have grown up and became best friends with a guy who becomes a master mechanic for MB. Then all of your operating costs would be in the basement
Old Aug 23, 2011 | 06:44 AM
  #32
£ C43 £ AMG £'s Avatar
E55K AMG
Originally Posted by BlownV8
Is your E55 a 4 matic? Front CV joints?
I knew there was something missing from my car!
Old Aug 29, 2011 | 01:14 PM
  #33
DML756's Avatar
Service cost per mile
Rondocap:
Thanks for the detailed write-up-. Seems as if your maintenance numbers are close to mine per mile. Expensive to be sure, but what a wonderful car is the S55.
I've been trying to deal with this vibration at low RPM/speeds.
First effort was replacement of front rotors (and pads), as these had tested slightly out of true.
I then replaced the damper for the ABC as the TSB description matched my symptoms exactly. Having put in the new damper (and filter and fluids etc) dealer-service reported motor mounts were shot so the vibration would not be cured. Your can imagine my dismay when , $950 poorer, I drove away from the shop and had exactly the same symptoms.
The independent service shop I have consulted said it is hard to pinpoint sources of low frequency vibrations as they can resonate throughout the car. Perhaps through MBWorld some solutions might be suggested.
Your point about going with a trusted indy is well taken. The nearest dealer (Chambers) charges on the order of $125/hr., well over double of various indys.
Old Aug 31, 2011 | 12:18 PM
  #34
rondocap's Avatar
Mercedes S55 AMG
DML756, it is definitely a wonderful car. I think if I were to do it over again, I'd get one with lower miles off the bat, that's still covered under warranty for a good amount of time. Outside of warranty, if you plan to daily drive the car, it can get very expensive compared to other vehicles.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
