My rear subframe bolt snapped
Old Dec 24, 2010 | 08:55 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Yesterday while doing my rear brake pad i noticed my passenger side rear subframe was hanging. Upon further inspection the noticed the bolt has sheered off. the mount still seems fine. I am about to go to a fellow members house to see if we can drill the bolt out and put a new one in. It seems like the bolt was snapped for a while becuase i noticed a unsual thud in the back of the car which started a couple of months ago.
which me all the luck, hopefully i can get this issue resolved.
Old Dec 24, 2010 | 10:01 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Good luck brother. Got to love Htown streets. Merry Christmas!
Old Dec 24, 2010 | 10:18 AM
shardul's Avatar
Hey sterling merry Christmas to you too
Old Dec 24, 2010 | 12:01 PM
TTMotorsports's Avatar
Whatever we're tuning!
You might as well change the mounts, stops and bolts on the subframe and rear carrier while you have it down.
Also weld up some plates to strengthen the floor where the subframe bolts attach so you won't tear the sheet metal.
GL with the repair Shardul. Definitely a PITA!! Do it once and do it right!
Old Dec 24, 2010 | 12:02 PM
lowprofile's Avatar
E55
Sorry to hear that. If you do not have it yet, the specs for that bolt are: M12x 86.5mm, 1.5 thread pitch. Merry Christmas and good luck.
Old Dec 24, 2010 | 12:04 PM
lowprofile's Avatar
E55
^LOL BB!
Old Dec 24, 2010 | 12:22 PM
LOCO 05' E55's Avatar
P-Carro
Here is how mine looked..passenger side.
Attached Thumbnails My rear subframe bolt snapped-broken-subframe-1.jpg   My rear subframe bolt snapped-broken-subrame-2.jpg
Old Dec 24, 2010 | 11:11 PM
£ C43 £ AMG £'s Avatar
E55K AMG
Yes PITA, happened to me, this is a weak area and can end up with both sides being pulled out of the chasis..........SARDUL catch it early before it gets more exspensive
Good luck
Old Dec 24, 2010 | 11:37 PM
Infiniti's Avatar
a unicorn tuned p30 e63
good luck with the repair shardul
Old Dec 24, 2010 | 11:47 PM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
sorry to hear about this brother, however, with the support crew you have down in Houston, I'm sure it'll be put back together in no time (and probably better than it was in the first place)
Old Dec 24, 2010 | 11:57 PM
Forrest Gump 9's Avatar
shrimp boat
To prevent this, can I just "routinely" change the bolts out?
Old Dec 25, 2010 | 10:56 AM
shardul's Avatar
ok guys we got the car fixed yesterday would not have been possbile without the help of AUS-E55 and Jerry@eurochagred. it took use about 4 hrs since we had to make 5 trips to sears. Now i think we can do the job in under an hour.
We drilled the old bolt out, and put a thicker and longer nut and bolt assembly. we had to cut some sheet metal in the wheel well to access the other side of the bolt. the reason i went this route is becasue i didnot want to drop the whole rear subframe since we didnot have access to a lift and time was an issue.
Guys all i can say is check your subrame mounts it seems like i was driving with a broken sub frame bolt for a while. If you get the deadbod thud in the back check the mounts.
Old Dec 26, 2010 | 04:45 PM
TopGun32's Avatar
im reading more and more about this issue.. and seems its a matter of time...
specially for the 2003 cars.
However I don't recall reading of any dealer fixing this issue under warranty or extended warranty.
I just had my radiator, trans and tq converter replaced, it turned out to be the coolant leaking into the trans.
When I first took it in, I thought it was the sub frame bolts and worried how the warranty was going to cover this repair.
if you can post any pics of the repair it would be extremely helpful.
Old Dec 27, 2010 | 12:07 AM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Shardul,
Interesting post. Will include a check for this in my mtce schedule. Just one question though. What was yr odometer reading at the time of the incident?
Brgds
Old Dec 27, 2010 | 12:58 AM
AWOL's Avatar
e55
Would something like this be covered under warranty?
Old Dec 27, 2010 | 08:43 AM
shardul's Avatar
Mileage was around 60k.
Warranty may cover it
Old Aug 15, 2019 | 09:13 PM
5150///AMG's Avatar
05' E55
can someone rear-ending you cause this to happen down the road, let's say 2 weeks after?
Old Aug 16, 2019 | 03:24 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Yes, easily! The parts become stressed under a crash and can break later.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 28, 2019 | 07:51 PM
pandy's Avatar
2006 CLS55 & 2011 G55 & 2xE55 Wagon
Hope it helps those in need before it happens
A rear subframe bolt DIY using a BOLT NUT WASHER to make sure the threaded part in the body is not ripped off in heavy acceleration.
Link to DIY https://stumptownbenz.com/e55-subfra...t-replacement/
Old Dec 30, 2019 | 03:28 PM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Awesome write up, thank you.
