Intermitent bad vibration
Old Jan 4, 2011 | 09:31 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Well, have not driven the car for 3 weeks and come home and give it a run.
The ESP malfunction message is still there no mattter how many times I turn the sterring wheel lock to lock.
The Parking sensors also now are playing up indicating an obstacle when none present. It then disables itself.
Now to the vibration....
Well I gave the car some spirited runs and then on the return drive it felt like I had a loose wheel!!! I immediately took it easy and babied the car a bit ... after a while it felt fine again and gave it some more gas and it felt OK.. but am having it checked over.
I am beggining to think diff carrier / engine or tranny mounts, or maybe diff itself, esp or dunno what...
It could also be airmatic as the issue only really became bad when I set suspension to sport 2 ... but after a fair amount of time.
Disconnected both batteries overnight and resetting the lot and see where I am at. But getting a mechanic over on sat to check it over... anything else to point him in the right direction?
And happy new yr to all ...!
Old Jan 4, 2011 | 11:35 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Check rear subframe mounting points
Old Jan 4, 2011 | 11:41 AM
stevebez's Avatar
I was hoping that by avoiding to mention it, it would not be the case, as the fix for that is nasty. I will check it anyway thanks.
Old Jan 4, 2011 | 12:25 PM
Forrest Gump 9's Avatar
shrimp boat
May be just cold tires. I know in my car the steering wheel shakes a little in the morning and get less/go away as the drive go on.
Old Jan 4, 2011 | 12:38 PM
stevebez's Avatar
I initiallly thot so too but the vibration was pretty dramatic...
Old Jan 4, 2011 | 01:20 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Sitting for 3 week will leave flat spot on the tires that what caused the vibration.
Old Jan 4, 2011 | 03:43 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
i 2nd this !!!! Soft compound Invo's are notorious for this !!!
Old Jan 4, 2011 | 04:36 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Could be flatspotting. Although most modern tires don't flat spot (like they used to.) But some brands are known for flatspotting even over a short time. Next time pump up the tires to 50 psi before you let the car sit for a while. That helps keeps them from flatspotting.
They should work themselves out after a long drive. If not then it's something else.
The parktronic sounds exactly like a sensor is bad. It's a quick fix with a new sensor (except you have to paint the sensor the body color first.) Same thing happened to me with the exact same symptoms.
Old Jan 4, 2011 | 04:45 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Motor mounts notorious on our cars. At least have him slide under or poke around up top with a flashlight and check for leaks (they have fluid inside)
Old Jan 4, 2011 | 04:53 PM
stevebez's Avatar
Ive disconnected both batteries and will see how I do on the esp / park sensor issue.
The vibration thing is really weird ... thing is it also comes and goes its not there all the time. But when it shudders its pretty substantial to make you wonder wtf is going on. Tyres were a little under inflated as well so ill pump them up to 3 bar and see if the issue is still there and then if gone reset to normal pressure.
Thanks for the input guys...
Old Jan 5, 2011 | 01:51 PM
TopGun32's Avatar
I had a rear vibration in low speeds.. it turned out it was the transmission and torque converter.
my exhaust note changed and the shifting started to thump around.
You have an '06.. therefore it could be mounts or suspension components.
Old Jan 5, 2011 | 04:26 PM
stevebez's Avatar
Hmm thnks for that - Yep it could be TC or the tranny - that feels like where the issue is coming from. mbe its my TCU software for the 2.82 getting knotted up... ugh that 2.82 diff ratio change was a palava of note and with minimal benefit in the end....
Ill start with the easiest fixes first and work my way into the abyss from there...
ecu reset
tyres
all mounts
prop shaft
suspension
airmatic
carrier mounts
tranny....
guess thats covers it...
Old Jan 9, 2011 | 10:13 AM
stevebez's Avatar
OK an update .. and good news.
Well pumped the tyres up and cycled the suspension settings a few times and voila - vibration gone.
TBH I think it was a damper which got stuck in an undamped mode when switching between C/S1/S2 ... if thats possible (anyone know?). I have been driving around in C mode for a while as this seems to eliminate any vibration. Now in all modes I am good....
