New Concept One CS-5 Concave
Old 07-08-2012, 01:29 PM
Former Vendor of MBWorld
FXAutodesign's Avatar
C-class
bump
Old 09-01-2012, 02:31 PM
C-class
PM sent
Old 09-02-2012, 01:02 PM
Bramage's Avatar
F-250
Originally Posted by efivefiveamg
The seller states they are only available in the following specs:
20x9.0 +25 or +36
20x10.5 +27 or +45
I for one really like these as an inexpensive option if you're into the concave look.
Which of the above offsets are appropriate for our cars and what size tires can we run?
For the front, a 20 X 9 (ET36) would be identical to an 8.5 with ET30. in terms of outside clearance - So that should be fine
Rear 20 X 10.5 (ET45) would sit out 1mm more that a typical 10" ET40
So, as long at you don't rub on the inside, these would fit pretty much dead on for the fender side, with room to lower.
The 10.5 is pretty wide, and it would sit 11mm closer to inside fender lining (rear)
If you want to see how various wheels will fit, you can use what is known to work well:
19X8.5 ET30 - ET32
19X10 ET38 - ET40
Then plug in new numbers on 1010tires Offset Calculator- That will tell you which way the wheel is going (in or out)
The lower the offset number, the more the wheel will extend towards the fender
Old 09-04-2012, 10:08 PM
C-class
bump
Old 09-11-2012, 12:41 AM
C-class
PM reply
Old 09-26-2012, 06:35 PM
C-class
bump
Old 10-06-2012, 04:29 PM
  #32
C-class
PM sent
Old 10-14-2012, 09:26 PM
  #33
C-class
bump
Quick Reply: New Concept One CS-5 Concave
