Has a cm30 ever frozen?
e55
Im in Buffalo, NY. Right now its ~20 degrees, maybe colder. The car has more power at 25% throttle, than it does at 75% throttle right now. Strange thing is, is that I hear the blower whining away - it just doesnt go anywhere. Everything is so delayed that the traction light doesnt even come on - and theres an inch of snow on the streets.
So has my cm30 gone bad? Frozen?
Normal driving is fine, idle is fine, no CELs. I checked the intakes, nothing is clogged.
Anyone ever experince this? Have any ideas?
e55
coolant
it jerks when I get off the throttle, and on the highway, if I floor it, it downshifted, revs shot up, but I essentially didnt gain any speed.
Ill be calling the dealer tomorrow, but if you guys have any ideas, Im all ears. There is a distinct burning rubber smell too, when I get out - but the belts looked good.
Maybe its the supercharger clutch? I really am stuck on this one
e55
I have not
Im only going based on what Im hearing. Its as though the blower is spinning, but making 0 power. I havent goofed around too much because I dont want to cause any damage.
Awol I have never had a problem in the cold , always seems to run strong, actually I think it runs even stronger in the cold. By the way. I just saw you on Delaware here in snowy Buffalo car looks great, yes even the blue wheels!
e55
The dealer is reporting back with a slight misfire, causing it to turn off the blower. There are no codes, and the idle is fine.
They recommend doing plugs and wires, then if that doesnt fix it, they will try coil packs, which would be under warranty.
Ill do the plugs myself.
Does this seem like a logical explanation?
e55
well, sorry for the triple post, but for some reason its fixed. I dont know what they did, they released it to me thinking it was still having issues, but for right now, its back to normal.
Maybe a plug wire popped off or something, or was lose, and during reassembly they fixed it.
