Replacing valve cover gaskets
Also, on the driver side cover, there is a upper portion that is about 16" long and contains the plastic fill cap. I assume this section also needs to be sealed with RTV sealant, as is done on the passenger side vent changer?
Thanks,
Todd
Thanks,
Todd
I just finished mine. Just dab some rtv in the 2 corners of the valvecover gasket. (front and back side of the cam) as far as the chambers you will want to remove those first while the valvecover is still bolted down, you will need to remove a few of the torx bolts to be able to remove the chambers, and then the little torx bolts holding the chambers down. You will have to pry the chambers off. Make sure you scrape ALL the old gasket off and spray them down with brake cleaner. Apply new RTV around both chambers and let them sit and tack up for about 8-10 mins then reinstall on the valvecovers. Its not bad at all I would change the Sparkplugs while you are in there LFR7AIX NGK plugs. Mine were almost seized at 60k!! some were really hard to come out. Hope this helps
Thanks,
Todd
