Any idea which one of these is the "pre cat" o2 sensor guys?
2003 E55 & 2014 GL550
Getting a bad O2 sensor error and it's time to replace them.
Getting 3 different part numbers from Autohauz.
Any idea which ones I need.
Is pre cat but the first O2s are gone obviously since I have long tubers.
Thanks in advance.
here is the link to Autohauz so you can see the ones I am looking at
Thanks in advance.
The info below is from the Bosch website:
http://www.boschautoparts.com/Vehicl...=OxygenSensors
You can either go with universal replacement O2 sensors, part number 15733, front and rear (requires splicing into your existing connector plugs), or with direct fit - as in direct plug-in to the factory engine wiring harness, using part 16272 for the pre-converter, and part number 16328 for the after converter sensor. If you're doing a complete replacement, you'll either need four of the 15733 universals, or two each of the 16272 and 16328. As an aside, Autohauz didn't have the best O2 sensor prices when I bought my spare set. Do a google for the Bosch part numbers and some comparison shopping because these things aren't exactly cheap.
15733 Oxygen Sensor - OE SmartLink - Universal Fit - Downstream Sensor Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V8-5439cc 5.5L FI EngDesg GAS
15733 Oxygen Sensor - OE SmartLink - Universal Fit - Upstream Sensor Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V8-5439cc 5.5L FI EngDesg GAS
16328 Oxygen Sensor - OE Type - Exact Fit - Downstream Sensor Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V8-5439cc 5.5L FI EngDesg GAS
16272 Oxygen Sensor - OE Type - Exact Fit - Upstream Sensor Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles V8-5439cc 5.5L FI EngDesg GAS
