SLR Disc replacement?
Front and rear Calipers and front discs. Discs are 360mm x 26mm so exactly in line with our oem ones... any clues if they are a direct swap , also the SLR 8 pot calipers are they different to ours, as the swept area on the disc looks a little narrower, so not sure ...
Any info welcome.
Disc Type : Vented / Studs 5
Disc Diameter : 360.0mm
Disc Thickness : 36.0mm
Min Thickness : 34.0mm
Overall Height : 64.5mm
Center Diameter : 67.0mm
Information
So 360x36x64.5 is confirmed ...
Guess calipers are a must then.
