Going to be running a split system have a question
here is the question ive read alot of people are running the new updated Bosch pump and they are same as cm30 but cheaper
is the new Bosch pump good enough to work in a split system, and will it break since it will be always on?
or do you recommend a cm30 pump ?
also i am not looking for a loud pump like meizier just to give you guys a heads up thank you.
