Oil Leak Help - PICS
when you putting back the oil pan bolts, did you add some liquid silicone gasket around the thread? look like some oil around the head bolts of the oil pan
oil filter housing seal
crankshaft seal
oil pan gasket..
those are pretty common leaks...
and you said you done oil pan and oil filter housing gasket.. double check again..possible that gasket for the oil filter housing is pinch...
best way is to start over and clean and diagnose the leak again...
