Fuse, I think...
Old Feb 18, 2011 | 07:30 PM
shooter's Avatar
2011 Ford Raptor, 2003 FX35, 2008 E63 AMG (Gone but not forgotten)
Fuse, I think...
So what's faster, and Ford Pinto or a Ferrari 599??
J/K
So here's my problem that hopefully someone out there has seen.
I started my car the other day and at the same time, rolled up the two front windows and then went to close the sunroof. The car started, but idled very hard at lower than usual RPM. I shut her off, turned off everything in the car, waited a few seconds, then started her successfully.
So get this, the auto up feature doesn't work now, but only on the front right window. It works on all the other windows fine, and the windows does roll up, just auto does nothing. I can't imagine there's a separate fuse for that feature, but it wouldn't put it past me.
I don't know if the auto down works, since I just washed my car and don't want to smear the glass.
Has anyone ever seen this? Think it's a fuse, or something worse, like a gremlin? It's still under warranty, so I'll take her in if it's not something I can fix myself.
Anyway, thanks in advance.
Todd
Old Feb 18, 2011 | 08:58 PM
Craigo's Avatar
Are you kidding? you can reset your windows for auto up/down. Hold it in the down positon till its all the way down, then hold it all the way in the roll up position till the window is up and you should have your auto features back.... i believe it's something like that
Old Feb 18, 2011 | 09:47 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Sounds like battery is going, have it load tested.
During the start the battery is being pulled down enough to cause loss of settings in the window modules.
Old Feb 19, 2011 | 09:09 AM
03'55AMG's Avatar
AMG
I had a similar issue where express would not work so I unhooked the battery and now it works on the windows but now sunroof? I even reset it by shutting it and opening it a hundred times.. It opens all the way express just not working when I shut it...
Old Feb 19, 2011 | 12:36 PM
shooter's Avatar
It's date night tonight with the ole' lady, and since we're supposed to get another winter storm up here, I'll try the close-open trick. If it doesn't work, it's off to the dealer for a warranty visit.
