What belt do I run with a ASP 175 pulley?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 19, 2011 | 03:41 PM
Roverron's Avatar
ML63
Trying out a 175 down from a 180. Do I need a new belt or will the 180 belt work?
Old Feb 19, 2011 | 03:42 PM
GT-ER's Avatar
2005 E55 AMG
Our tensioners have a lot of travel so I would guess the same belt could be used...I'm not sure though.
Old Feb 19, 2011 | 05:00 PM
grantwoodtx's Avatar
GLE 63S
I'm running a new Eurocharged 172mm and the K080514HD was a fairly tight fit but I know the same belt works with the 180mm pulleys.
Old Feb 19, 2011 | 07:18 PM
Roverron's Avatar
ML63
Thank you for the quick replies..
Old Feb 19, 2011 | 08:18 PM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
I run a 180mm pulley with a 514HD belt.
Old Feb 20, 2011 | 04:34 AM
ASP's Avatar
ASP
2016 Freightliner "daily driver"
I run the 514hd also with the 180mm pulley but I've destroy them and also destroyed my tensioner because it has very little play left. So after doing some research if you are running the plenum spacers which I am, it is better to actually run the 525hd which is slightly longer.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
