Blown engine 09 e63
#52
I've requested a compression test of all cylinders to ensure no loss. I've also requested that the cylinder sleeve be inspected, replacement of the connecting rod barrings, and review of the crank for any potential issues. Having a bent rod can be very bad for the cylinder and crank, so it really requires someone who knows what they are doing to get it back to 100%.
TheVoid
#53
They simply aren't required to replace it nor do they have any obligation to do so under the terms of the warranty.
I'm a business man and understand this, however there is good faith and the need for repeat customers. I for one will not be purchasing another Mercedes. They have lost any future business from me.
TheVoid
#54
W220 S65 AMG
This sounds like a nightmare.
I always wondered if Mercedes-Benz dealerships around the world treat their clients the same way that they do here in the States.
I feel like the dealership is "doing you a favor" by working on your car.... ridiculous.
#55
2005 E55 AMG
My issue with the rebuild is each engine is balanced. All the pistons are weighed and matched during the build process. Unless MB blueprints each engine component I may have issue with getting a part that is not optimum for my engine. Having a piston which is not exactly the same can cause some loss in HP. Furthermore, with the bent rod and crappy service to this point, im concerned that the rebuild will not be of the same quality.
TheVoid
TheVoid
#56
E63,,,not any more,,,BMW X5 50i
I don't know if you have already done this or not,,,,but why don't you try and post this on the AMG PL,,,,they usually have several AMG folks looking at the posts, and if anything, you could ask the administrator for help!!
JAT
JAT
#57
It's the AMG "Private Lounge" for any AMG owner. To get access, just sign-up and have your VIN handy. Here's the URL:
http://www.mercedes-amg.com/#/home
You see all this? I'd do a search and see if there are more...
https://mbworld.org/forums/ml55-amg-...wn-engine.html
#59
2007 E 63
2007 E63. Kablamo...
I have a 2007 E63 and it grenaded in F1 style today. 37.7k on the ticker, and I feel pretty confident that the dealer is going to confirm this. Large white/light blue plume, and washing machine idle. Not pretty. I had a motor let go in an E46 M3, and this was an even more dramatic. I creeped over to the side of the road and called roadside. Same comment at first from the dealer, "bad gas?"..uh, no. Sucks too, I just put some wheels on it Thursday..
http://i1102.photobucket.com/albums/g446/GCIP1/ride.jpg
#60
Best of luck to you and post back when you know something!
TheVoid
#61
Sorry to hear about this saga. For an engine that's supposed to be "bullet proof" it seems to me that there are proportionally too many stories of valve, cam adjuster, gaskets failures.
I wonder if a contributing factor could be the long time it takes for a MB dealer to sell these cars, when new. In my searches for a '09, I'm seeing a good number of Carfaxes that show sitting on a lot for 6 mo to a year or more before being sold. That can't be good. Same goes for the long stints, at a dealer, for used ones.
Add to that the fact that many owners of these cars put very little mileage on them, compared to an E350/550.
#62
2007 E 63
Thanks for the replies. Actually, my car was just at the dealer for a rattling noise I thought was the heat shield. Turns out it was broken baffle inside one of the cans. They replaced the whole unit from cat back. However, they mentioned that they replaced a gasket, which I thought they said was the header gasket? but I will have to check which one it was. I also had them replace the whiney power steering pump too. So far, they've taken care of me, including hooking me up with lowering the car via the Star thing. I'm curious if an over-rev during a transmission upshift could do it. I could swear my tranny seemed a little sloppy lately. Thoughts?
#63
'15 E63S wagon
Its nearly impossible to get HP values within a 10HP window between two dynos of the same brand in 2 locations. Additionally, there are so many different dynos out there, a perfectly healthy 63 engine can vary greatly between 360-410rwhp depending upon the dyno make, operator, etc. It's not as simple as you may expect.
Expecting a dyno reading between 405-415rwhp having never dyno'd your car before is shooting in the dark at best and may unfairly indicate "problems" with your engine when there are none.
#64
'15 E63S wagon
I like those wheels...which ones are they?
#65
2007 E 63
Thanks. They are the Vossen VVSC 2, I believe, with the shadow finish. They look incredible, the pic I posted was on my phone and doesn't show the concave form. I looked for a while, and have gone the BBS, Hamman expensive route, and for a car that is over 4k lbs, I don't really care if they are a bit heavier than a forged set. I have a 911 T and that is where weight would matter for me. Chris at DNJWheels in CA took care of me, and I was impressed with their service and timeliness.
#66
2007 E 63
Got a call from the dealer today. They said there was a rep in town, and they determined that there was a faulty injector. I told the service advisor to go ahead and get a loaner for me until the new lump comes in, cause there is no way an injector would cause a white mushroom cloud like that, I don't think. He agreed and said they have to go through the procedure, but "the car would be perfect before I got it back." I can see this taking a month easy. Next the Rep may find a loose wire, then a loose washer fluid cap etc. which would each take a couple days to order and re-test...
They couldn't get the car to turn over, let alone start when it came off the flatbed. Injector?? Really?
#67
btw, did your dealership have the regional MBUSA tech come out and assess the issue before they attempted to "rebuild" your motor? Or did the dealership take it on their own to do this (and get rebated $$ under the warranty)?
I'm curious because as I mentioned earlier, my SA and SM both said they can't rebuild the motors and crated replacements are the only option. Plus the MB tech people want to see the motor and figured out what happened for their internal records. I don't personally know of any dealerships that are allowed to rebuild the AMG motors.
#68
Additionally, I would hope most dealerships would not expect or want a non capable technician to work on a major engine repair- AMG or not. It is a big liability for the dealership and technician!
#71
Any other E63 with M156 failures? This issue is begining to surface over at the C63 side: https://mbworld.org/forums/c63-amg-w...-concerns.html
#72
RR Evoque Dynamic, Benz Valente (work hack)
God I hate coming back onto these forums with new M156 issues.
I have 64000 miles on my 07 ML63, redline it daily and all fingers crossed has no issues.
#73
07 E63. 07 STi limited #606/800
I drive mine like a maniac with a free pass to drive wild. I don't really speed too much, but I get up to speed very quickly.
I don't necessarily beat on it, but once the engine oil temperature is above 80*C I tend to start working her in up the RPM's. So far 73,000 miles and not a problem.
#74
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
#75
I started driving my STi a lot more and left my E in the garage for a good 2 months. Battery died and everything, ended up buying a new battery and the car was really running weird, sounded like she was mad at me for not driving her, like ticking and making some weird sounds I've never heard before.
After a few days of romping shes feeling much healthier.
