Whats the differnece between these two xpipes?
Looking to buy an x pipe and saw these two online,which one would you pick? I will be putting it in place of 2nd cats and replacing resonators with straight pipes.
http://cgi.ebay.com/ebaymotors/T304-...5ad8886a3#shId
or
http://cgi.ebay.com/ebaymotors/ws/eB...:MEWAX:IT#shId
Im leaning towards the magnaflow because it ships from Canada which means cheaper and quicker shipping to me.
or
What are the sound benefits? More aggressive when you get on the gas? What about drone at lower RPM's? I'd just be replacing the resonator, not getting straight pipes.
E55 w/ goods, Z32 Project underway
I have the top one, exhaust guy figured I spend way more than I did for it. He said it was a quality unit and he does all sort of hot rods, etc. No issues. No magic with X-pipes and i seriously doubt one will flow more than another unless there is a design issue or really serious bends.
Many of those have other mods to the exhaust such as cut muffler, different muffler, no muffler, etc. I have resonator and 2nd cat deletes and it sounds good with a low end growl and a bit louder top end without sounding raspy nor any resonance.
Well I got shangoashe selling me his brand new Fedor Dezyn x pipe for a good deal. Tbal, who did your exhaust work? Im guessing speed syndicate?
PLATINUM SPONSOR
To be honest, I would not use either.. They are both stamped metal and not as nice as a smooth, mandrel bent and tig welded X pipe.. Pypes makes nice X pipes and so does Burns.. Pypes is more resonable.. I think there is a decent one in Dr Gas too.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2005 E55 AMG
Risk what? It's an X-pipe, not a piston...lol.
