Play in front wheel
Old Apr 5, 2011 | 11:08 AM
Forrest Gump 9's Avatar
shrimp boat
Play in front wheel
Last night while doing engine and transmission oil change on my car we (me and Evolved8) discover that there are some plays in the front driver side. Just wondering if that's the sign of bad wheel bearing or balljoint? Thanks in advance.
Old Apr 5, 2011 | 11:28 AM
grantwoodtx's Avatar
GLE 63S
Was the play vertical or horizontal play? I had a similar issue and if you jack the car up and push upwards on the wheel and you hear a bump it's more than likely your ball joint.
Old Apr 5, 2011 | 02:52 PM
bmontalban's Avatar
2007 E63
i had lower control arm bushing go out on my 07 e63, front driver
Old Apr 17, 2011 | 09:54 PM
shrimp boat
I finally have a chance to check the play in the front wheel today. The play was horizontally. Very minor. Also I was check the ball joints, there are three of them, one on top and two on the bottom. Which one should I replace? Thanks.
Old Apr 17, 2011 | 10:24 PM
buffyclk500's Avatar
clk500
have a friend move the tire left 2 right and things that move u need 2 fix
