Secondary Air Injection System Malfunction
In my case i had to replace the air pump and the relay. The air pump was dead since it was permanently switched on by the bad relay and died. When i came home one day i turned the car off and heard it running and didnt know what to do...so i let it just gradually die. A few days later, CEL turns on with p0410. Now I know which relay needs to be unplugged should have ever happen again.
Anyway, I recorded the whole thing and put it on youtube. Its a pretty easy repair and cost around $475 to do yourself.
Enjoy!I also need help locating the relay.
There was too much oxidation! I don't know how it happent.
I posted 2 pictures,please can you look and what should i do for cleaning.
Is that a problem and effects to what? and how?
I cleaned two hoses connected to air pump check valves but i dont know how to clean air pump check valves and also there is EGR valve,should i clean it too? and how?
today i will change the sc fluid and clean those corrosion from there!
please ask someone who know that problem! it looks water turn around there inside and made that corrosion. but how!
