Renntech header cracked again???
Old Apr 12, 2011 | 01:22 PM
alltrac's Avatar
2004 E55
What the heck man...first it was the passenger side...now its the driver's side. Im tired of these overpriced piece of @#$% headers.
Old Apr 12, 2011 | 01:34 PM
BenzoBoi's Avatar
Super Moderator
W221
Time for Long Tubes's...
Old Apr 12, 2011 | 02:10 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Ouch.... not good!!! Have you talked to them about it yet? They are sponsors on the board now. How long have you had them on the car before they cracked?
Old Apr 12, 2011 | 02:41 PM
komp55's Avatar
ML550
Have you checked the condition of your motor mounts? If they've failed or are failing, it's entirely possible that the engine is flexing side-to-side too much under load. No header will withstand excessive rotational flex, particularly when connected to the stock E55 exhaust system which has fixed attachment points about a foot downstream of the primary converters.
Old Apr 12, 2011 | 02:46 PM
RENNtech AMG's Avatar
Former Vendor of MBWorld
Mercedes, AMG, Porsche, Bentley, Audi
Alltrac- I am hoping we may have outside forces or another unusual parameter causing this problem. I can be reached directly at 561-845-7888 xt 23 so we may schedule a time convenient for you to examine your vehicle closer.
Regards,
Mark @ RENNtech
Old Apr 12, 2011 | 04:12 PM
alltrac's Avatar
2004 E55
Actually, I contacted u guys when the first header cracked and u guys were of little help. My motor mounts are ok and the cracks develop at places where there are welds.
Old Apr 12, 2011 | 04:18 PM
slownrusty's Avatar
'06 E55 K2
My recommendation, if you decide to repair the cracked \ failing welds is to ceramic coat (or Jet Coat) the headers to keep the heat in the pipe and protect the stainless steel...the cost is marginal compared to the benefit.
I had my Kleeman headers Jet Coated last year and a firm believer in this process.
Old Apr 12, 2011 | 07:01 PM
alltrac's Avatar
2004 E55
you might be right...
Old Apr 13, 2011 | 10:27 AM
Unfortunately, I am unsure of what the problem may be or under what circumstances we were unable to help you the first time. If you would like to discuss having the situation resolved, you may want give us the opportunity to correct it, especially since you are indicating a problem with both headers which is a product we have sold countless units and had hardly an issue with. If so, you may contact me here as previously posted.
Thanks- Mark
Old Apr 13, 2011 | 10:54 AM
GT-ER's Avatar
2005 E55 AMG
Actually, keeping the heat inside will make the header expand even more which would make cracking more likely. Cracking headers are due to bad design and/or welding. There is no easy way to get around that.
Old Apr 13, 2011 | 11:09 AM
AMGV855's Avatar
E55 AMG
You are correct GT-ER, keeping the heat inside will, well heat it more and be more likely to crack.
However when ceramic coating headers, it can be and usually is done on the inside and out of the headers which lowers the overall temperature of the headers and will be less likely to crack the bad welding/design. Slownrusty was on the right path.
Old Apr 13, 2011 | 11:27 PM
alltrac's Avatar
2004 E55
Thanks- Mark
Ok, ill drop you a line and we can discuss the issue...
Old Apr 16, 2011 | 01:47 AM
alltrac's Avatar
2004 E55
Thanks- Mark
Called and spoke to Mark from Renntech today. He was very helpful and was genuinely concerned about their product and the fact that my prior contact with them regarding the other header cracking didn't go well .
He offered me an option of setting up an appointment and bringing them the car so they could perform the labor of removing the headers at little to no cost. Even though, this was an option, I already had the car at another shop (prior to discovering the crack...thinking it was a leaking gasket) replacing all the exhaust gaskets, so I decided to leave it there.
Either way, he assured me that Renntech would in fact replace or repair the headers free of cost (even went as far as providing free shipping back and forth)!!!! I will follow up how everything turns out, but so far Renntech and Mark looks to be genuinely concerned...
Old Apr 16, 2011 | 02:03 AM
Viet_Amg408's Avatar
Pinto
that's how all should work
Old Apr 16, 2011 | 02:10 AM
W211 BEAST's Avatar
2006 E55 BEAST
+1^. I love seeing things like this getting resolved so quickly and as painlessly as possible due to good customer service. Props to Renntech.
ShangoAshe's Avatar
2020 AMG GT-R PRO
props to renntech
Old Apr 16, 2011 | 02:30 AM
BenzoBoi's Avatar
Super Moderator
W221
Kudos to Renntech!
Old Apr 16, 2011 | 02:34 AM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
radTECH
Old Apr 16, 2011 | 04:41 AM
_AMG_'s Avatar
C63
Are the cracks by the flanges?
Im glad to see Renntech is taking care of the problem.
Old Apr 16, 2011 | 07:34 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Renntech Good news
That was very good of them; Now you can make the GTG at Markham park on the 30th. Cheers _PTEngineering
Old Apr 16, 2011 | 05:29 PM
alltrac's Avatar
2004 E55
what GTG???? Im 15min away from that park...
Old Apr 28, 2011 | 11:26 AM
ALLtrac:
As an update: Both of your E55 RENNtech headers have been completely updated, reworked and just came back from ceramic coating. Here are some updated pictures:
The headers are being shipped back to you today standard overnight with new gaskets and copper paste for the install at no cost to you. Thanks again for you patience and we appreciate your business.
Regards,
Mark @ RENNtech
Old Apr 28, 2011 | 11:33 AM
viper04's Avatar
very nice!!
Old Apr 28, 2011 | 11:58 AM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Nice looking headers
Old Apr 28, 2011 | 05:59 PM
MB_Forever's Avatar
Nice pics Mark
