My GM302 Build Out........
I am actually thinking about that, Its actually producable and I am in Chicago, the first problem is the weight.
Block = 180lbs
Top Glass = 90lbs (At Least)
Bottom Glass = 35lbs
Wood Base = 15lbs
So it would need to picked up locally, the next question is what would somone pay for it?
It actually lights up underneath (Which is why the 1/2 inch glass below) so in the evening it looks like the cylinder holes are glowing, its pretty sweet. If you look close you will see the taplights
Block = 180lbs
Wood Base = 15lbs
