My Compression Test Results
I have a MB 82mm sitting eventually i will put it on. i have installed a couple of 82mm kits on other E55s.
All are in between 10 and 10,4 bar which equals 145 to 150psi i guess.
The engine was not in operating temperature, this means that in operation temp. the pressure is slightly higher
It Flowed 930 CFM. Then I installed the Y from a 80 MM set up. It Drop to 850 CFM. That is a 80 CFM drop? I'm looking to install this type of set up on my klee blower. I need to do more fabrication. If I was shipped a stock 74 mm , I would flow it for comparison against one with a Shaft grind done by (NOT ME) enough interest we will start a new thread
Cheers _PTEngineering
Here are the results. WIS say the compression number should be within 22 psi of each cylinder which I think is too much.
It is a pretty straight forward procedure, just remember to disconnect the CPS which doing this test so this will prevent the engine from starting.
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
If anyone has done this please can you share your results. Does anyone know what the compression results should be on a 55k motor?
Cylinder 1 162
Cylinder 2 162
Cylinder 3 162
Cylinder 4 162
Cylinder 5 162
Cylinder 6 165
Cylinder 7 163
Cylinder 8 163
Compression test result:
C1 175psi
C2 175
C3 175
C4 175
C5 170
C6 175
C7 175
C8 170
Leak down test result:
C1 3%
C2 3%
C3 3%
C4 3%
C5 3%
C6 0%
C7 3%
C8 3%
