My Compression Test Results
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Since I am running a bigger pulley and have other mods I figured I would do a compression test on my car. After doing this I think this is a must for all the heavily modded cars. Exotic-Metal55 was kind enough to lend me his compression testing set.
Here are the results. WIS say the compression number should be within 22 psi of each cylinder which I think is too much.
It is a pretty straight forward procedure, just remember to disconnect the CPS which doing this test so this will prevent the engine from starting.
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
If anyone has done this please can you share your results. Does anyone know what the compression results should be on a 55k motor?
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
https://mbworld.org/forums/w211-amg/...on-values.html
WholtdCl55amg (02-06-2022)
Agreed! If you test your compression with 10 different gauges, you will get 10 different set of results the key is consistency from one cylinder to another. Shardul, all your compression results are in a 6psi range low to high so excellent numbers!
Yasin
Yasin
Just curious, what are the cylinder order or location? By that I mean, what cylinders are on the passenger and driver side and in what order if I am standing in front of the car.
2003 E55 & 2014 GL550
Those are higher than the mighty Alan monster. His were 150ish across the board.
Gotta be some of the highest I have seen Shar.
I don't have one cylinder over 150 I think.
My rings must have setup horrible.
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
Btw.my brand new engine which i have just broken in shows 140 PSI on all 8 cyl. with mercedes OEM tester and WIS testing procedure on cold engine and 500 meters altitude with 0W-30 Castrol SLX Professional eng.oil. Engine is silly strong with that numbers.
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
Cylinder 1 161
Cylinder 2 155
Cylinder 3 160
Cylinder 4 160
Cylinder 5 161
Cylinder 6 160
Cylinder 7 161
Cylinder 8 160
Brgds
WHAT WHAT![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Best thing about your sled Shardul, is that is alomst looks stock rolling down the road. Love your stock CLS rims and subtle upgrades. Only thing giving it away is the rumble of that exhaust![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Any chance you could take a clip of your rpm gauge when you got WOT in 1st, 2nd
Any chance you could take a clip of your rpm gauge when you got WOT in 1st, 2nd![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
the high torque numbers are due to the 190mm.
once i get me rear tank install i am sure i will pick up some hp up top that I have lost due to high IATs
Keep in mind i still have a stock TB
'13 GT-R AMS Alpha 9+, CLA45, E55
Jesus shardul, your car is a monster. And a very healthy monster to boot! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
530rwhp and 630rwtq...![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Congrats! Yourself, Jerry and the Houston crew build some great rides
