Help. Front bumper extension
Old May 1, 2011 | 05:41 PM
Lee6082's Avatar
2005 E55,172 pulley, H/E, shorty headers. 1985 280sl euro
I'll try to keep this short.
I'm cruising down a 2 mile access road going home from church just minding my own business. When I notice a cts-v coming up on me. He pulls up, eye contact is made, I hear three beeps and we bury our pedals. I pull on him a little and it stays that way. At 142 mph I hear a thump, I let off the gas, and hear something knocking with a very even tempo. I put it neutral and shut her down. No smoke, no smell. When I stop and pop the hood and I go to the front of the car I look down and notice the plastic pan that used to be fastened under the bumper is hanging down. I am relieved to say the least as it sounded horrible as the wind forced it down so low that it was bouncing off the pavement. Now I'm just pissed that it can't be salvage and am sure the AMG tax will apply.
Anyone know the part number?
Old May 1, 2011 | 05:52 PM
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
I will get it for you hear soon, just need to get back to my computer to look it up
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Is this one of the belly pans, under the oil cooler or engine?
Old May 1, 2011 | 06:37 PM
Forrest Gump 9's Avatar
shrimp boat
I took all the undertrays off the first time I work on the car. Helps the car run cooler and easier to retrieve drop tools.
Old May 1, 2011 | 07:06 PM
mikey33's Avatar
Here is the part # you need A2115201322. $176.40 at parts.com
Old May 2, 2011 | 12:17 PM
Lee6082's Avatar
Thanks Mikey. However I looked up that part number on Parts.com and "no part found" came up.
Yuille36- it is the belly pan that is directly below the front bumper and meets the belly pan under the engine.
Does anyone else feel that these pan are not needed and help cool the engine better?
Old May 2, 2011 | 12:36 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I get too scared of road debris etc so I keep mine on.
I have a question for anyone...have you ever heard of this happening???
On a stocker there has to be 6 or more bolts snugged up to hold it in place.
Just don't get how ALL of those bolts could let loose and it come down. Not doubting your story, just the last guy to tighten those bolts (or didn't)
Due to massive intercooler hoses etc all over my undercarriage front I can only get a few bolts in and still has never dropped down on me.
Just found that weird.
Old May 2, 2011 | 12:37 PM
Yuille36's Avatar
I don't feel that they aren't needed, as it keeps all the road grime from splattering up onto the engine. And also protects the engine if you were to hit debris from a truck tire, etc. I do agree that removing them would help mitigate heat, but mine are staying put.
Old May 2, 2011 | 12:45 PM
mikey33's Avatar
The name is splash shield and yes that is the correct part, remove the letter "a" when searching.
Old May 2, 2011 | 01:48 PM
Yuille36's Avatar
I could understand two screws becoming dislodged, but the entire pan!
Old May 2, 2011 | 04:17 PM
komp55's Avatar
ML550
The pan not only serve as a splash shield to protect the engine compartment, it also affects air flow underneath the car, contributing to a reduction to the coefficient of drag of the car. Mine will be staying in place; and I definitely agree with those that suggest there's no way it would pop down if all the attaching fasteners were correctly secured.
Old May 2, 2011 | 06:23 PM
Yuille36's Avatar
I know that my splash shields have naca ducting, to direct cool air up to the engine mounts.
Old May 2, 2011 | 09:20 PM
Lee6082's Avatar
Thanks Mikey for the part #.
I recently had a pulley, h/e, I/C pump, headers and a tune installed. It looked to me that bolts may have been loose and at that speed the it caught the wind and ripped the plastic off the pan. The rear bolts were still attached and tight.
I will be replacing the pan. Thanks for all feedback guys!,,,
Old May 2, 2011 | 10:36 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
