Torco accelerator
Old May 4, 2011 | 08:26 PM
darmawaa's Avatar
2011 E63 AMG
Torco accelerator
Anyone use this?
http://torcoracefuel.net/pro-accelerator.html
If works, it's very simple way to get race gas performance with premium fuel
Will it left deposit on spark plugs if used regularly?
Old May 4, 2011 | 09:36 PM
Quadcammer's Avatar
96 and 08 911 turbos
yes, it works very well, but you will get the reddish MTBE deposits on your plugs.
If you use it in fairly high quantities (more than 1 32oz bottle per tank), you may need to replace your plugs more frequently.
Old May 5, 2011 | 02:08 AM
Thericker's Avatar
V12-Biturbo
I've used it on my biturbo frequently, had plugs changed @40k Techs A close friend of mine: Reaults. aflter using lots of Torco were great if h got the right mix. Having said that turbo's react much more portintley than Kompressors ie turbs luv d stuff. having said that I Saw .zero plug reidue... I'd use. it 1-2 mo on near full tanks on otherwise crummy 91. I have since got around 10gal true 109
Old May 5, 2011 | 11:31 AM
e500slr's Avatar
2011 E63, 2013 CLS63
Sounds good, especially considering most don't work as proven on Fifth Gear. Does it contribute to engine wear or....?
Old May 5, 2011 | 01:06 PM
Quadcammer's Avatar
as far as I can see, there is no reason why it should contribute to engine wear. Just make sure to get the unleaded version...the leaded ones beat up cats and 02 sensors.
Old Aug 13, 2012 | 08:54 PM
AZBENZ-CTSV's Avatar
PORSCHE PANAMERA TURBO LAMBORGHINI GALLARDO SL600 E55 BRABUS*SOLD*
I've found nothing that works better than the TORCO stuff.
Old Aug 14, 2012 | 12:40 AM
ajm55's Avatar
2006 E55 AMG
I use the stuff but in my experience, the gains on the 55 motor are negligible unless you specifically tune for it. With a tune, I got about 10wkw at the top and as much as 15wkw at about 5,000 rpm. The ratio used was one bottle of Torco to 40 liters of fuel
