150 mph pull
Old May 10, 2011 | 04:51 AM
black05scamg's Avatar
2005 e55 black on black 07 e63 po30
150 mph pull
On my way to work I did a hyw pull up to 150 mph afther that
My car started to shake like I blew my motor up but once I shut her down I started hEr back up and she seem fine WTF
Old May 10, 2011 | 05:41 AM
gts007's Avatar
06 E55 AMG, 86 Corolla,87 E30,02 LSB M3
nice.
Old May 10, 2011 | 06:56 AM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
i can only think the car is leaning out up top , your getting more air flow , your exhaust is opened up so its flowing better so now you need to more fuel . i would relax on the top end runs until you Tune the car
Old May 10, 2011 | 07:06 AM
I knOw but at 4am its hard not to push this *****
Old May 10, 2011 | 07:49 AM
skratch77's Avatar
2005 E55
I never push my car past 3rd gear going wot.melting cylinder 8 comes to mind every time lol
Old May 10, 2011 | 09:06 AM
jmb614's Avatar
E55 AMG
Could bigger injectors be in order?
Old May 10, 2011 | 12:27 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
It wont melt at those speeds
He most likely has a leak of some sorts. Check TB, and all your gaskets for leaks
Old May 10, 2011 | 01:08 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
But you left out one important variable, "Catch Em" your friendly neighborhood state trooper, at that speed your going to jail. Those speeds should only be done on the track. You were flirting with disaster my friend. I'm still a little shell shocked about doing 97 mph in a 55 last September and going to court, and facing $2500 fine, 1 yr suspension and 7 days in jail. Luckily, I had a good lawyer. Paid $150 fine, $82 court fee, and 5 points. I learned my lesson.
Old May 10, 2011 | 01:39 PM
GregMB's Avatar
Any chance you just bumped up againt the factory top speed limiter???
I don't know how the factory actually cuts power (cut spark, remove timing, removes fuel or some combination).... but I'd imagine no matter how they do it, it's going to cause a pretty noticeable stumble once you get there.
-G
Old May 10, 2011 | 02:28 PM
GT-ER's Avatar
2005 E55 AMG
Did the shaking continue until you stopped and turned the car off or did the car go back to normal as soon as you let off?
Old May 10, 2011 | 02:40 PM
Yeah As soon as I shut her down and stared back up
She was finE
Old May 10, 2011 | 03:09 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
These cars are freak shows sometimes. Happens to me all the time. Hard pull up to 3rd and then at a redlight, the car feels like its a pro stock car idling.
I have cams and stuff but still! Weird.
Old May 10, 2011 | 04:31 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
-G
ive bounced off the speed limiter a few times in several models MBs and it just gave u a dead pedal until your MPhs drop down again , no bogging or stumbling from what i remember
Old May 10, 2011 | 04:37 PM
GregMB's Avatar
That makes sense... I'm guessing now that the MB is "drive by wire" throttle, so it would be a lot simpler to just ignore the extra throttle input to hold the speed steady at the factory limit.
Those other techniques I listed are better suited for the mechanical linkage-type vehicles.
-G
Old May 10, 2011 | 05:10 PM
_AMG_'s Avatar
C63
+1
I have pushed my car to 150mph+ speeds on wide open roads as well (wont say where) but I feel lucky not to have been caught.
It really is playing with fire when you are in the 90-100mph range.
Im not planing on doing that again unless im on a track.
Old May 10, 2011 | 05:35 PM
I just checked it out with a scanner cly number 8 mis fired
Why maybe it went real lean
Old May 11, 2011 | 01:58 AM
alextaylor29's Avatar
2004 E55 AMG
I'm lucky, I have a 1 mile flat private road just by my house that goes into a state park and closes at dusk. It's exactly 1 mile long, 2 lanes and empty of any traffic.
I do half mile blasts on it all the time, late in the evening 10PM - 11PM or so and have a half mile to slow the beast down.
Once I get my headers installed I'll do this again. Hoping to hit 150 MPH! I'll film it as well so you'll have proof.
But again this is basically a closed road after dark with no cross traffic, cross streets.
I lub it. (hehe...)
Alex
Old May 11, 2011 | 08:47 AM
skratch77's Avatar
2005 E55
Pull your spark plug and look for oil.might as well do a compression check on that cylinder while your there.
I hope its nothing but your car shut down the cylinder and went into limp mode.
Old May 11, 2011 | 09:58 AM
I am gonna check it now see if there's oil there
Old May 12, 2011 | 09:19 AM
I tired to take off the spark plug but I coulnt get my driver in there the socket
Was to fat plus the yesterday when my friend asked me to rev my car so he can hear it with the hood open I heard a lifter hit once it sounded like it hit the
Valve cover but it I haven't heard it again
Old May 12, 2011 | 11:17 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
I go 150+ once a week or more on public roads, waaaay out in the middle of nowhere. Let the preaching begin. Solid as it gets at those speeds.
Old May 12, 2011 | 11:26 AM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
+1 ... This car is truly uneventful at those speeds.
Old May 16, 2011 | 02:13 PM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
My sentiments exactly. My car is stock but 150 mph is merely 13 seconds of WOT from 100 mph...no big deal...
Brgds
Old May 16, 2011 | 05:11 PM
Nino S's Avatar
2005 E55 AMG
do these cars having issues cooling at WOT runs at those speeds. That was a HUGE issue on the 03/04 Cobra and many killed their motors that way. A couple comanies came out with head cooling mods that evened out the coolant accross the motor. I did a 155 mph pull the day I bought mine and it felt solid as a rock. Anyone else have more info or a link about cylinder #8 going lean and how to reduce that chances of this happening? I am going with a stage 2 package from eurotune next month and wonder if the fatter tune will help with the new pulley. thanks!
