cd stuck in command
I'll have to try the battery trick. I've had the previous owner's CD stuck in there since I bought it. Occasionally I can get it to recognize and play the CD, but it won't eject it.
SL 55 AMG 2003
Ok, I tried the push the eject button for 30 sec. Didn´t work. I tried disconnecting the back battery for 1 hour. Didn´t work. If You peek inside the slot, You see one small ( mine are white )plastic pin almost in the middle, and 2 little bigger plastic pins ( white too ) in between the center and side of the slot. I have been pushing these side pins more to the side with a wooden sticks You use for making barbecue skewers. Didn´t work. But today I pushed these pins to the sides again, and then pushed the left one towards to the front of the car ( went pretty far ), and a miracle, 2 discs came out from the slot. My nav disc and Billy Idol cd put in by previous owner ( I think ). After that I put my nav cd in, ejected it, in and out, in and out. It works fine now. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I still wonder, why it sucked my nav cd in ok, when there was a disc inside already.
Anyway, everything is fine now. Everybody with the same problem, try that, it may work for You too.
SL 55 AMG 2003
