Help finding part numbers...
Why would you need part numbers
1130350200 $655.00
You will also need a new crank bolt as they are one time use only.
Alldata info, part will probably be cheaper on Parts.com, or free if you take it in under warranty like others have stated.
if it is covered under warrranty why would you need the part numbers. Now if you need the price of a crank pulley it is about 400 to 500 and the bolt is 30.
