Misfire 5,6,7
When I sprayed my cam covers, I noticed that each coil pack has a designated location...
did not notice this before...
And I must have had these packs off and on about 10 times since Ive had the car ... So in case you guys have not noticed there is a specific order to where they go in... its coded on the plug boot and the cam cover at each location. I dont think it makes too much difference, but I suppose there had to be a reason for them having this coding.
So I put it back together in the right manner, and while I have not activated the aquamist again, I have zero codes as yet. Will try again soon with spray on.. I am spraying ahead of the intercooler.... FWIW
On another note, anybody who isnt running rear 02s, where are they sitting? Did you weld bungs in?
Hmmm, I had mine off for the header install. Perhaps coincidence or maybe there really is something stupid about how mercedes did it, either way I will check it out.
after a wot run ... as the system seems to spray 2-3 seconds after I have come off the trottle for some reason
Always the same side / cylinders 5&7 ...
How you coming on tibi?
I am simply going to stop spraying it on the street and keep it for the track
Any update on this situation?
I have similar situation with my car, misfire and the car around 1800 - 2400 rpm seem to be suffocate and it gave small smoke. I stopped spraying and this is the second day but I don't drive the car for long, I will check in 2 more days how the car feels.
I have the nozzles after SC, before the IC. Even when I use only water, similar situation. What size of nozzles guys are you using?
My engine mods:
- 82mm TB
- Brabus Pulley
- KLEEMAN headers
- W/M post SC but pre IC
- 550cc Fuel injectors + TTM rail design
FF LT headers 2 200 cel race cats secondary o2s disabled but there are bungs and they are in. No issues for 1 month prior to having eurocharged flash the car for the headers, now after timmay fest I have been throwing the codes weekly... Any thoughts?
Ill try fiddle with the trigger point and mbe set the start point at a higher IDC, so I use less water and see if it still happens.
I dont get why I get misfire at part throttle (low IDC) when I should be spraying nothing at anything less than 70-80% IDC...
Mbe its the interaction between the ecu electronics and the Auquamist unit. Ill set the flow to a higher IDC and see if it returns.
I run my nozzle after SC, before the IC. Nozzle size is 550 cc/min, will a tune will help? I am waiting to get a tune and maybe re check again.
For the past few weeks I have been having some random misfires. There isnt one specific thing that I am doing to cause the misfires, and they do not happen every time I drive the car.
Two weeks ago, at the track, at the end of the run the while downshifting the car made a loud exhaust noise and the check engine light came on. Cylinder 5 misfire.
Last week, driving down the highway just cruising and all of a sudden is sounded like a helicopter was above me, check engine light came on. Tried to accelerate car fell flat on its face, so I pulled over shut her down, looked around saw nothing wrong. Fired her back up and she drove fine. Code said cylinder 5,6,7 misfire.
Today, I was cruising with my parents in the car, and it repeated last weeks behavior. I haven't checked the code yet, I will check and post the exact code tomorrow. However I am willing to bet 5,6,7 misfire.
Mods:
MB 80mm tb
Cooling mist Water injection (windshield washer fluid with 2 cap fulls of meth)
FF Long tubes
Eurocharged tune
Could you gent help me narrow down where to look?
When doing a compression check should it be done WOT?
Need ideas, my drag setup arrived yesterday, so I would like to resolve this before Friday night.
