Under the knife part two, HELP needed guys
Old Jun 2, 2011 | 02:33 PM
jmb614's Avatar
E55 AMG
Perhaps the mezeire is having a hard time forcing coolant through the CM-30, since the CM-30 flows less. It sounds like the pumps are connected in series, I would have similar pumps if that is the case. Just my 2 copper.
Old Jun 2, 2011 | 02:54 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by chawkins2001
We added the cm30 back there, and it increased the flow tremendously, however, the Meziere pump upfront was making a very audible humming noise. How loud are the meziere's, because when it was pumping on its own, it was dead quiet. Anyone have a sound clip of their meziere upfront pumping?
mine is loud as a **** as well.....
Old Jun 2, 2011 | 03:43 PM
chawkins2001's Avatar
2006 E55 AMG
Do you have a sound clip, mine sounded really loud.
Old Jun 6, 2011 | 10:00 AM
2006 E55 AMG
Unfortunately guys, the blower has to come off again. The aftermarket intercooler was flowing way to much liquid to fast, and could not keep the IATS down. We are going to put the stock cooler back in, and leave all else the same, and try one more time to tune the beast for TimmayFest. I did add another Meziere pump in the rear, so I have one in the front, and one in the rear, and still could not bring the temps down after routing the plumbing like exotic metal and sharduls setup. No more bubbles either in the tank after it was bled thoroughly. This is with the stock manifolds and gutted secondaries.
I will keep you posted but will not give up yet
Old Jun 6, 2011 | 10:11 AM
jmb614's Avatar
E55 AMG
Good luck dude, I hope the stock intercooler does the trick. Did the pumps quiet down when you swapped from the CM-30 to the Mezeire on the secondary?
Old Jun 6, 2011 | 10:31 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
To all the people who have the Meziere pump if they get loud it means the bearing are failing. sent it back to meziere and they will remanufacture the pump. I have had 2 mezieres go bad on my car, after remanufacture they are fine.
Old Jun 6, 2011 | 10:55 AM
  #32
viper04's Avatar
Good
Good to know, I did not know this.
Old Jun 6, 2011 | 11:47 AM
  #33
2006 E55 AMG
Yes, once I added the second meziere pump, both are whisper quiet.
Old Jun 6, 2011 | 11:52 AM
  #34
jmb614's Avatar
E55 AMG
I had a similar issue in a PC watercooling setup a few years ago, two different pumps in series. Once I installed a duplicate and removed the pump that flowed less all was fine.
Old Jun 13, 2011 | 03:22 PM
  #35
2006 E55 AMG
That is very interesting man. A second meziere pump was added outback next to the cooler tank in the trunk, and still had sky high IATS. As a result, there has yet to be a dyno pull, and start the tuning.
Thoughts are to now take out the two meziere pumps, and add to more duplicate pumps that suck and push the water at the same time.
Shardul, if you still have that 5 gallon tank, pm me your best offer shipped to GA 30064 buddy. That coupled with a Bilge 2000 is a known winner
Old Jun 13, 2011 | 05:17 PM
  #36
shardul's Avatar
sorry man hammerdown bough it.
i can get one made for you. it will take about 2 to 3 weeks.
Old Jun 13, 2011 | 05:29 PM
  #37
2006 E55 AMG
Pm me the cost on it mang, thanks buddy.
Old Jun 13, 2011 | 06:21 PM
  #38
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
so is it better to have the return (hot water) push into the reservoir from the top or the bottom? I would guess have the return line enter the top and the suck line pull from the bottom ?
Old Jun 13, 2011 | 07:10 PM
  #39
2006 E55 AMG
Would that actually matter though, just thinking aloud.
Old Jun 14, 2011 | 03:23 PM
  #40
2006 E55 AMG
Anyone, does it matter where the return line is routed, at the top or bottom of the tank?
Old Jun 14, 2011 | 03:41 PM
  #41
GT-ER's Avatar
2005 E55 AMG
The water will flow better on top as it will not have backpressure from the water inside the tank ( gravity will try to push water back ).
Old Jun 14, 2011 | 03:51 PM
  #42
loungn14's Avatar
SPONSOR
thats how i have mine...makes it easy to purge air lol...
Old Jun 14, 2011 | 04:09 PM
  #43
2006 E55 AMG
I am assuming the bilge is a pushing and the meziere a sucking pump?
There website says that the Bilge1100 (27D) would fit, which might be good since my tank is only 3 gallons vs. your 5 gallon tanks.
Old Jun 21, 2011 | 09:48 AM
  #44
jmb614's Avatar
E55 AMG
How's your beast coming along?
Old Jun 21, 2011 | 10:55 AM
  #45
2006 E55 AMG
Figured out when we switched from the factory 5/8" hosing to 7/8" hosing going into the intercooler below the blower, it was too big. All the pumps we tried could not flow enough water to keep it cool. Stuck a water hose in there and turned the pressure up, viola, temps started to come down big time.
So, we are taking the blower back off for a third time to switch back to the 5/8" sizing, running a meziere 20gpm front and back. Makes us think, that was the intercooler we had custom made really the problem since it had massive chambers like we thought.
Our plan is to get it back up and running with the trunk mount system, tune it, and then take it apart again, stick the bigger intercooler back in there with 7/8" hosing and run massive Meziere 35gpm pump upfront and back. Just want to see if the intercooler below the blower can actually lower temps even more with monster pumps.
Old Jun 21, 2011 | 11:30 AM
  #46
Evolved8's Avatar
AMG Fam
Pictures!!!!
Old Jun 21, 2011 | 01:36 PM
  #47
2006 E55 AMG
There are no new pics as it has been trial and error. 5/8" hoses are been replaced today which means pulling off the blower and hopefully hitting the dyno tomorrow.
Old Jun 21, 2011 | 03:50 PM
  #48
Evolved8's Avatar
AMG Fam
Keep us updated
Old Jun 23, 2011 | 09:29 AM
  #49
2006 E55 AMG
My beast is all under control now, ahh, where to start. Long story short, when all the new rubber 3/4" hosing was installed, it had tiny little rubber filings in the hose, and as a result, alot of it got stopped up in the rear tank screen. The screen was 80% blocked, and as a result I was not getting much water flow.
So my current setup right now is rear meziere and front meziere with a trunk mount. We started the tunning, and at WOT I am seeing temps around 120. It drops back down quickly to 10* within ambient after 15 seconds.
Once we get the car buttoned up, it will go back in for the FF header install, cutouts, and re-try the aftermarket intercooler and bigger hosing again. That way we will know for sure whether the cooler helps or not.
In stock form, I put down 360rwhp on the dynamics dyno, and last night in the preliminary stages, I am at 425rwhp. Power mods I added are 180mm pulley, 82mm throttle body and off course the tuning. My exhaust is all stock minus a secondary cat delete, and magnaflow mufflers with stock manifolds upfront.
Old Jun 23, 2011 | 10:30 AM
  #50
jmb614's Avatar
E55 AMG
Thanks for the updates. Good luck with the header and intercooler install! Keep us posted
