ECU pin out for the MAP sensor..?
Old Jun 9, 2011 | 01:34 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Ive probbaly asked this before but still have not found out the answer....
Any clue which ECU pin reads the MAP sensor data?
Old Jun 9, 2011 | 01:36 PM
jmb614's Avatar
E55 AMG
A pin-out diagram for the entire ECU would be nice, or at least + - K-Line etc.
Old Jun 9, 2011 | 02:49 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Attached Thumbnails ECU pin out for the MAP sensor..?-me_needs_2.jpg   ECU pin out for the MAP sensor..?-me_needed.jpg
Old Jun 10, 2011 | 04:43 AM
stevebez's Avatar
so is the pressure sensor the MAP sensor? red/grey, location 3-10?
or is that the oil pressure sensor?
Thanks for the help !
Old Jun 10, 2011 | 07:45 AM
shardul's Avatar
yes. it shares the ground and power with another sensor.
component 3/10 is the ECU
Old Jun 10, 2011 | 08:26 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Map sensor Pin outs
Hope this helps
Cheers PTEngineering
Attached Thumbnails ECU pin out for the MAP sensor..?-map-wiring-medium-small-.jpg   ECU pin out for the MAP sensor..?-dsc00594-small-.jpg
Old Jun 10, 2011 | 09:11 AM
stevebez's Avatar
thanks guys so red-grey (socket3-location10) is 0-5v output and pink-black 5v input (which also powers the oil sensors) and brown-grey -ve ground?
Just to clarify!
Thx again guys!
Old Jun 10, 2011 | 09:42 AM
PTE's Avatar
PTE
Pin outs Map sensor
On most Euro cars Brown color is the Earth / Ground. I tried to post a color schematic. The colors fade when enlarged
Old Jun 10, 2011 | 11:17 AM
stevebez's Avatar
but the above is correct?
Old Jun 10, 2011 | 12:12 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Do you have a voltage meter Steve? Be good to confirm it with that.
Old Jun 10, 2011 | 12:37 PM
shardul's Avatar
true but how are you going to produce boost so the sensor sends a signal. unless you have a boost leak checker but that will confuse to ecu if it see boost at idle or when the ignition is in position 2
Old Jun 10, 2011 | 06:10 PM
stevebez's Avatar
yeap got a meter but trying to hook it up is not easy esp when trying to get a boost reading!!.. at mom I am tapping off the red-grey and see how it goes... its for my water injection think I may go boost based flow instead of IDC based flow.
Old Jun 10, 2011 | 06:51 PM
benz_addict's Avatar
V12TT
thanks shardul and PTE!
Old Jun 12, 2011 | 07:41 AM
stevebez's Avatar
for those interested...
IDC is socket 3, pin 27, grey-black
MAP is socket 3, pin 10, red-grey
+ve injector side, socket 5, pin 9, red-blue
