CLK320 drags rims, pics inside plus more
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
I just picked up a set of four of these bad boys from fleabay today, so let me know if anyone wants the other two. They weigh only 13.1lbs, and I plan to smooth the lips back out, and plasti dip mine. I will do the other two for free to sweeten the deal.
I do have a question though, do we need spacers to run these, and if so, what size?
![](http://i1098.photobucket.com/albums/g365/chawkins2002/WHEE155.jpg)
You will need a 15mm-17mm and off course with that comes getting yourself longer bolts as well, 2" long should do. Not sure you are aware of the bolt diameter being smaller on these wheels...so you will need to grind these holes a bit to fit your bolts..
And last but not least, these bad boys WILL turn on your DR's
So get yourself a "bead lock" kit
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Good Luck and stay thirsty my friend
They are 16x7 with a 37mm offset. As mentioned above, you need to drill the holes in the rims to fit the plump e55 lugs which takes about 5 minutes per wheel. You also need to pick up a set of spacers.
Only thing I am unaware of is the bead lock kit, did you get that from Summit, and do you have a part #?
Where do you get the longer lugs from?
Its no required to take this step until you actually mark your tire and rim at the track..also track must be hooking real hard for this to occur.
To bead lock them you need a Drill bit and pick whichever screw size you want. I got mine from local store.
Hard to tell from this video but they turned on the tire during this launch and screwed my 60'..this was before bead locking them
http://www.youtube.com/watch?v=PmMwHwzdfpk
Just watched your video, shyte, you were rolling out brother. What gear selection did you use in the water box and what is your exhaust combo. She sounds raw bro
Super Moderator
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
2003 porsche 996 turbo
and back at you again! before you drop big bucks on the hoosiers look at the goodyear eagle ss dr. 2 lbs heavier than the hoosier but substantially cheaper. its what i have on my clk rims and hooked hard enough to break my diff in my old 32 in reynolds ga. in may!
Former Vendor of MBWorld
Any spacers you guys need we can get for you. We have a large selection of different sizes in stock and we will be happy to source out anything that you need.
-Craig
-Craig
