ESP Malfunction
Old Jul 4, 2011 | 10:37 AM
AMG-NYC's Avatar
2005 E55 Wagon
ESP Malfunction
Happy Fourth of July everyone! Unfortunately my '05 E55 wagon is indicating the ESP malfunction warning. Several weeks ago, I had complete electrical failure and had to replace the auxiliary battery. Now I have been getting the ESP warning. I have tried resetting by turning the steering wheel lock position to lock position several times. And still no luck. Does anyone have any other suggestions? Thanks again!
Old Jul 4, 2011 | 03:16 PM
dannish23's Avatar
'07 e63 AMG, '06 e320 CDI, '07 ML350 4Matic, '18 Gls450, '12 cls550
im new to all this too.. but ive had mine on for quite awhile now.. and i believe its because one of my rear tires are really worn out. it says "ESP Inoperative". maybe check your rear tires? idk. just a random guess..
Old Jul 4, 2011 | 04:25 PM
AMG-NYC's Avatar
2005 E55 Wagon
Thanks but its not a tire issue. This is most likely a result of the electrical woes i had. What are the chances its my steering angle sensor? BTW - there are no codes from my OBD.
Old Jul 5, 2011 | 05:17 AM
Mantooth's Avatar
2004 E55 AMG
I would try resetting the car by disconnecting the battery. See if that fixes it.
If not, take it in for service.
Old Jul 5, 2011 | 01:28 PM
ExoticToysNyC's Avatar
2 S 55 AMG
have someone with a star system hook up to it. if you don't know anyone with one send me a pm...i can take a look at it...i'm in queens.
Old Jul 5, 2011 | 02:05 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Yes hook the car up to STAR DAS and it will extactly tell you what the problem is and which sensor to replace. Most likely it is the wheel speed sensor.
Old Jul 5, 2011 | 09:18 PM
AMG-NYC's Avatar
2005 E55 Wagon
Thanks everyone. I have a scheduled annual NYS inspection at the dealership, so they are likely to give some sort of diagnosis. I will let you all know.
Old Jul 5, 2011 | 10:17 PM
2 S 55 AMG
like i said before, i can hook it up to star free of charge to see what the problem is, i'm not sure how the dealers are where you go...but most will charge diag or labor time fee just to do this, plus an arm & leg to fix it(no offense to my dealers)...and we also do nys inspection. either way hope you get the problem fixed.
