Kleemann Intercooler
Is it more efficient & larger than our stockers? If so is it compatible? If not can it be modified to work with our S/C & ECU?
Are you talking about the top mount ic? If so awhile back, there was a car with the Kleemann top mount IC was sold on here. I think StreetKing bought it and then re-sell it shortly after that. And that's the only one Ive seen around.
The Kleemann Kompressor unit consists of a Roots type Kompressor with an integrated air-to-water intercooler and is the only known system to combine the intake manifold, kompressor and intercooler into one integral unit
Former Vendor of MBWorld
If we're talking about the actual core (not the radiator) yes, it's much more efficient and has a lower pressure drop. Unfortunately, the cores themselves would take significant fabrication to work on a 113K engine- may as well fabricate SLR-style units if you're going to go that far.
