Starting issues.. Not cps!
Old Jul 15, 2011 | 02:08 PM
kompressorfed's Avatar
MB
So this morning my car wont start the first time, it will start on the second or third try. I changed the cps last summer and it is not the same thing again. Seems like fuel pumps or fuel relay problems from what I've read on here. I checked under my seats like 4 months ago and there were no leaks from the pumps/filters but now since the starting issue I hear a buzzing noise comming from under the rear seat? Gonna check my pumps and relays right now. Any other thoughts? Thanks!
Old Jul 15, 2011 | 02:28 PM
edmond1129's Avatar
E55
Check also the fuel socket in the trunk, I got it melted once
Old Jul 15, 2011 | 10:23 PM
MB
Checked the fuel socket on the right side, and everything was fine. When I removed the backseat and started the car, the pass side fuel pump was humming pretty loud. Never heard this before untill the problems started. So I need a new pass side pump? The part number I got from it is A211 470 1794, is this still correct or is there any updates on the part#? Anyone know how hard install is?
Old Dec 27, 2012 | 03:15 PM
nphra's Avatar
2004 E55 AMG
Hello,
I know this is an old posted but i did like to know how you solved your issue. I have the same problem now. Please help. Thanks
Old Dec 27, 2012 | 04:22 PM
efiftyfizzle's Avatar
W212 E63 AMG S Model
Originally Posted by nphra
Hello,
I had a similar issue as well. It wasn't CPS for me... but apparently some fuel leaked and shorted the harness for the fuel pump. I ended up having to replace the pump and harness at the stealership. Wasn't a cheap bill...
Old Dec 28, 2012 | 11:08 AM
nphra's Avatar
2004 E55 AMG
Thanks for the reply. I will, focus on the fuel pump.
Did your pump running or making sound when you have the key in the "ON" position?
Old Dec 28, 2012 | 02:25 PM
I can't remember to be honest with you... it literally happened like right when I got the car and I didn't know too much about all of these issues. I happened to do all the research about it after I got the problem fixed because from what it sounds like, it's likely to happen again.
