Old Aug 29, 2011 | 03:08 PM
Monster E55's Avatar
2003 Mercedes Benz E55
I have purchase a 2003 E55 AMG what a great car.
Am new to this forum. When I bought the car it had a warning light CAR TO LOW took it in to thee dealer to fix 3 times they never fixed it now they are out of business and I am stuck with fixing out of my own pocket .
Old Aug 29, 2011 | 03:18 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Should be one side dropped lower than the rest. Any idea from visual which side and corner.
Drivers front?
Most likely shock/airmatic strut but could be compressor pump/air pump or leak in the lines.
Old Aug 29, 2011 | 03:27 PM
BenzoBoi's Avatar
Super Moderator
W221
Welcome!
I would recommend just swapping out to a nice set of coil overs. Rides well and is less problematic.
Old Aug 29, 2011 | 03:58 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Does the car have aftermarket lowering links? if it does you need to make sure that they are not set up too low if they are you will be having this problem. Does the car lift the front end when you drive and when you come to a stop drop? It should be an easy fix if this is your problem.
You also want to check for maybe a broken link or a link that might have snapped off your suspension.
Good Luck
