180mm vs Bigger???
The mods on the car that this would be going on would be full bolt on, meaning
Heat Exchanger
Long Tubes
Pump
Secondary tank in the back
(possibly top mount intercoolers)
Injectors
and all the other supporting mods.
This car is not daily driven, drives out only on the weekends from time to time, but I am looking to make the best power possible, I think I'm more concerned with the car pulling harder on the street than RWHP or RWTQ on the dyno (thinking that the 190 will make more but at the track it will MPH slower hmmm)
KAMIL
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
i feel that larger than 180 for street use can be annoying. s/c engagement becomes abrupt and quirky and can get embarrassing when jerking passengers around.
Heat Exchanger
Long Tubes
Pump
Injectors
KAMIL
I can give you a ride on sunday...
Craig you can send your heads in but it will tame about 4 weeks to get them done. I don't want to tell you it will be 2 weeks and then it takes more time.
