Spark Plug Comparison
Parts: $292.00
Labor: $520.00
Total: $812.00
Not only that, I also ordered the supercharger and the v-belt from primeparts. Cost me total of $88.00 delivered. Dealer quoted $314.00 total.
So if I went with the dealer, the total cost would've been $1126.00. BIG Thanks to mbworld AND the folks that have posted the DIYs, it'll only cost me $242.80 and a few hours on Saturday.
No doubt many stealers replace "defective"plug wires rather than performing this venerable procedure.
We used a dab of anti seize on the plug threads and a dab of dielectric grease on the boot wire to plug connection.
Finally, after all this, if you get a misfire try switching spark packs from one cylinder to another. Be careful because the wires and packs have an interchangeability order, they are not all the same. I took a before picture of both banks as well as looking at the diagram on
www.mymercedesparts.com
For a further reference to the M113K engine.
Just some tips. Comment: The spark packs on the m113 and m113k v8 are epoxy sealed and should be quite rugged vs the infamous v12 packs in the turbo environment.
here's a good pictorial of what happens to plugs
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
2006 cls500 manual says .039"
hope this helps clarify
Based on my small sample of NGKs, I recommend checking the gaps on new plugs rather than assuming they are all accurately set at a predetermined gap. I just bought and gapped 18 of the NGK LFR6AIX-11 plugs. Yes, it's a small sample, but the gaps were definitely not consistent across the batch. Three of the 18 were at the gap I was setting (I used 0.032), and the rest were closer to 0.040.
But maybe some of our cars dont like the colder plugs mine loves em and it drives, idles, and cruises exactly like it did with the stockers heck even my mileage is same.
You must be fast to get all 16 plugs done in an hour! I spent a good hour getting one side done, but I didn't copper grease the plugs last time so I have to turn it like 7 times before it starts loosening up and turning easily :P. Also I don't have a good extension length and have to work around with too short and too long
Maybe my idle is the injectors we will see I have new plugs going in now did one bank last night do the other bank tonight.
You must be fast to get them done in an hour, I have to struggle against the plug for like 7 full rotations before it starts easing up on me. Probably should put some copper Q1qQQwzQqqqqqwww²grea222w3w33a2qq in grease on. I also am a bit short on appropriate extensions and either have too short or long so am working around that lol
