DIY for rear mount tank?
Anyone have a DIY for rear mounted tank for supercharger cooling? How to route hoses, flow patterns etc. Pictures would be great. Searched but didn't see a "DIY" just a lot of finished product threads. Messaged Shardul but feel bad harassing him every other day LOL...
Thanks guys
Thanks guys
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Parts needed
1. 40ft 3/4 rubber hose
2. clamps
3. misc 3/4" 90 degree fitting
all you have to do is route the hose under the car and up to the front wheel well to the pump. make sure non of the lines have kinks in them. if you need to make a bend use the 90 dgree fitting. depending on your mounting location you will have to drill 2 1" holes some where in the trunk for the inlet and outlet hoses.
flow patten has been discuees in my previous thread. check on **************.com there is a lot info you all can use.
2. clamps
Shardul any links?
Is it better to go from the res to pump to intercooler, instead of res to pump to HE to intercooler. Wouldn't the second way be better for daily driving, wheres the first method would probably be better for track use. IE ice box...
thanks
thanks
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Same looked but nada
Plus whats up with this bull****...
Somebody in need of members... desperately? lol
Hey there!
It appears that you've exceeded the maximum number of posts you can view, but wait, there's a simple solution. To unlock the forum and continue viewing messages, all you need to do is sign up for a free account. The entire process takes just a few minutes so create your account now and view as many threads as you like!
Already a member? Login at the top of this page to stop seeing this message..
Thanks guys
Thanks guys
If you end up doing this I want in!
It took me a little bit to get past the Supergirls forum :p after that I couldn't get any pics to show at all!! I am not interested in doing a remote reservoir right now but thought I'd snoop around.
